XJ650 Leaking fuel line
  • Monoideism
    • Jun 2024
    • 1
    For the love of variety, this tube's packed with all sorts of flings: one-on-ones, threesomes, and even some full-blown orgies. Get ready for curves that won't quit and peeks at forbidden pleasures straight from India's bedrooms to yours.
    https://indianporn.ooo/videos/72712/...her-full-body/
    https://tamilporn.tv/videos/57209/bb...esi-housewife/
    • 1820
    Most Japanese bikes can use 1/4" inner diameter fuel line available at any auto parts store. Some bikes use 5/16" but pretty safe to say a 1982 bike uses 1/4". You might have to remove the carbs/airbox to get to the inlet (usually underneath in the middle of the carbs). Be careful as the inlet might not be aluminum. It might be plastic and could break if you force the old line off or the new line on.
    • jkorn
      • May 2003
      • 187
      • Wickenburg AZ
      My 1979 Yamaha XS1100 uses a 5/16 fuel line which is also happens to be 8mm which I’m guessing was the original spec. I purchased it from Amazon.
      Jeff Korn
      Original Owner 79XS1100 E
        • 2072
        I buy Tygon fuel line on E bay. I also will put the ends in hot water to soften them up and then immediately put them on the petcock.
        • rdmycguy
          • Dec 2020
          • 29
          I just replaced on my 650....T fitting is between #1 and#2 carb, it's a little easier if you remove the gas tank....dont forget petcock vacuum line
