I cant win!
  • Lord Grizzlon
    • Mar 2003
    • 101
    • Bklyn, NY
    I cant win!
    After long waiting got Exodia runnin ----again...
    rebuilt starter
    cleaned carbs
    set timing
    replaced head gasket
    checked and changed clutch
    new reg/rectifier
    new stator may go on after turkey day
    plus some cosmetic changes to make my special special
    now i have carb blowback on #1. spits like she has phlem. the other 3 are ok. then she'll stumble from idle -3k. after that climb no problem, but smetimes comes down slowly
    ideas?
    gt501s come after we fix this prob
    L. G.
    1979 XS1100SF
    Exodia, "The Forbidden One"
    1988 CBR600F Hurricane
    Tempest- died Aug. 10, 2005
    198x XS850
    -no name yet-
  • BLUEJEEPLAB
    • Sep 2005
    • 703
    • Miami Valley, Ohio
    Not an XS expert, but I had a similar problem with an RD which turned out to be a Reed Valve broken off. Intake Valve stuck maybe?
    Papa Gino
    79 and something XS 1100 Special "Battle Cruiser"
    78 XT 500 "Old Shaky"
    02 Kawasaki Concours "Connie"
      • 7831
      I would start with a compression test, If it's good, go back to the #1 carb and check float height. You may also want to check for any leaks around the intake manifolds.
      Check for correct routing of fuel lines, and be sure breathers (vents) for the carbs arre not plugged. The vents are the TOP "T" fittings, and go to the top of the air cleaner. They look like fuel lines, and do get "crossed" sometimes.
      Ray
      • Geezer
        • May 2003
        • 2985
        • Willamina, Oregon 97229
        Assuming the compression is good (check it first,) did you replace any carb parts?
        New pilot jets from Mikuni look more or less the same but pass mant times more fuel per jet number than stock. Also K&N aftermarket jets and other aftermarket jets are commonly way off and aren't worth using. If this is the problem #1 plug will be black...
        Geezer
