3d printable parts repository
  • OldGreyBeast
    • Mar 2024
    • 100
    • Florence, AL, USA
    These are the 3d printable replacement parts I've made so far. I'll add more as I design them. Feel free to add your own creations! All of these have been tested on my bike and work properly. If you don't have a 3D printer but are interested in these parts, shoot me a PM and we'll work out how I can print one up for you.
    Rear master cylinder boot:
    https://cults3d.com/en/3d-model/tool...-cylinder-boot
    Battery Tray:
    https://cults3d.com/en/3d-model/tool...0-battery-tray
    Airbox rubber vibration damper:
    https://cults3d.com/en/3d-model/tool...h7-14452-01-00
    Headlight switch (internal and external):
    https://cults3d.com/en/3d-model/tool...l-and-external
  • jkorn
    • May 2003
    • 188
    • Wickenburg AZ
    Nicely done. A real practical use of those printers.
    Jeff Korn
    Original Owner 79XS1100 E
    • OldGreyBeast
      • Mar 2024
      • 100
      • Florence, AL, USA
      Here's 2 more parts. Still have a few more I need to add. Would it be possible to get this thread stickied?
      Headlight bucket damper:
      https://cults3d.com/en/3d-model/tool...-bucket-damper
      Middle/Rear drive oil level checker tool:
      https://cults3d.com/en/3d-model/tool...e-oil-dipstick
        Would be nice if you could come up with this part. It is number 30 on this schematic. Yamaha Motorcycle 1980 OEM Parts Diagram for REAR WHEEL | Partzilla.com
          Yes, that's a good one!
ID:	881093 Click image for larger version
ID:	881094 Click image for larger version
            However, it would need to fit over the head of the pin. The original material is rubber so it flexes quite a bit.
            • OldGreyBeast
              • Mar 2024
              • 100
              • Florence, AL, USA
              Looks like it would be simple enough to replicate I'll see if I can snag some measurements off the one on my bike (assuming it's still there). The rubber parts can be printed with TPU, has a nice flexible quality but still very robust.
              • OldGreyBeast
                • Mar 2024
                • 100
                • Florence, AL, USA
                That part is totally gone on my bike, but I took some measurements. I'll get it into CAD and print a beta test soon
                  It would be cool if it was universal to fit both the Special and Standard.
                    Standard and Special are two different pat numbers. They DO fit all years of each model, though.
                    32 1J7-25374-00-00 SPACER, TORQ.STOP (92901-08100) . . . . . . . . . . . . . 1 Standard
                    31 3H3-25374-00-00 SPACER, TORQ.STOP . . . . . . . 1 Special '79
                    28 3H3-25374-00-00 SPACER, TORQ.STOP . . . . . . . 1 Special '81
                    • OldGreyBeast
                      • Mar 2024
                      • 100
                      • Florence, AL, USA
                      If anyone has one for a standard that doesn't mind sending it to me I'll duplicate it!
                        I can't find what I had, but I can tell you the overall length is the same, as is the center hole. the difference is the width of the "outside" rubber. As I don't have the part, I cannot be exact but I believe the Special is 2mm for the outside, and the Standard is 6mm.
                        • OldGreyBeast
                          • Mar 2024
                          • 100
                          • Florence, AL, USA
                          Interesting, I wonder if mine has a standard swingarm then... I measured mine at 2mm on the inside and 5.5mm on the outside.
                            Swing arm part numbers are all the same. So I could be wrong on the measurement, as I'm not sure if the swing arm has been "worked on" with my Special. My guess is the difference is about 5mm between the two, measured from the swing arm going to the rim.
                              The torsion plates are different between the two models, one having an open end slot and the Standard a closed oval hole.
                              The bushing for the Standard may need to flex some to install it.
