carb rebuild
  • railroad
    • Aug 2004
    • 28
    • San Diego,CA
    carb rebuild
    I been looking for a carb rebuild kit for my 1980 xs11g . all i can find are kits for the lg,lh,sh 80-81 and the 80 sg. are any of these carbs the same as a G
    Thanks for any help.
    SETH MILLER
    The kits SHOULD be the same. Check your frame for the build date, and try to check your carbs with the yamaha site. IF the kits include new jets, BE CAREFULL!!!
    Some of the companies that supply jets with the kits put in the WRONG size! The best thing is take apart and clean your carbs, replace the needle and seats, and float bowl gasket, and put them back together. Unless you have a LOT of miles on the carbs, the rest should still be in good order, once cleaned.
    Ray
    • RiskyBusiness
      • Mar 2003
      • 174
      • Richmond, Virginia, USA
      I have been told that all versions of a given year run the same carbs. Can anyone confirm this?
      1979 XS1100 Special with 81 carbs
      • xj11john
        • Jun 2005
        • 440
        • Lafayette, TN
        I've had my carbs apart 3-4 times and gaskets were fine, unless they tear you should be ok with the old ones.
        '82 Xj1100j
        "Ride for the Son"
        John
        • LoHo
          • Sep 2002
          • 1342
          • Fresno, CA
          I just did my 80G carbs, got the parts from Parts n More.
          • railroad
            • Aug 2004
            • 28
            • San Diego,CA
            thanksguys , I plan to tearthem down next week.
            SETH MILLER
