Need a few things. Best source for parts?
  • 596silverblue
    • Mar 2024
    • 13
    I hope this is the right place for this. Anyway, I know there are a lot of online sources for parts, but I'm leery of ending up with counterfeit/knockoffs. What's your most reliable/trustworthy source for basic stuff, like tires, plugs, etc? After that, where would you go for more XS11 specific things? Thanks in advance.
    • 7819
    I don't do all that much online for basic parts. Tires, go to a local motorcycle shop. A few bucks more, but they can mount and balance and usually stand behind them. Spark plugs and oil, Napa or another good auto parts store. MikesXS is a good online source for parts, but they do carry some suspect parts as well. If you look through some of the repair threads, you can see who we have used, and who we avoid.
      • 8062
      http://partshark.com
      Actually, the list is very long. There are a lot of good parts out there and a lot of junk.
      Here’s a good link:
      BS34 carbs Throttle shaft seal Suzuki part # 13651-51010 SEAL I replaced the butterfly shaft seals with these Suzuki seals they fit perfectly. Cost a dollar less than the Yamaha seal ..... https://www.partzilla.com/product/suzuki/13651-51010 5twins tip We've discovered an even cheaper source...
      It’s XS650, but much applies to the XS11. Late XS650s have BS34 carburetors.
      • 596silverblue
        • Mar 2024
        • 13
        Thanks. I use a local mechanic, but he doesn't stock parts and just advised me to get my tires online, etc online. None of the larger shops here will work on carbureted bikes - at all. Even the dealers who sell new japanese bikes won't touch my XL, so I feel lucky to find this guy. Anyway, just looking for the best source. I'll be putting some of it on myself, but not tires and such. Currently looking for some new carburetor manifold boots, and was told to be careful about Ebay because the counterfeits of these are very common. Ideas for sourcing that particular part?
          • 8062
          For carb boots, check
          I got mine at Parts n More over 10 years ago. They’re still going strong.
            • 8894
            I always get my tires from chapmoto.com, they are always new fresh stock.
            • OldGreyBeast
              • Mar 2024
              • 100
              • Florence, AL, USA
              I usually get my OEM parts from Partzilla.com or Babbitsonline.com, whichever has it in stock. Tires I generally get on Revzilla, but I have a NoMar and do my own tire mounting/balancing.
              • 596silverblue
                • Mar 2024
                • 13
                Looks like I can get OEM carb joints on Ebay for about $25, NOS. Probably a better option than Chinese "unbranded," based on all I've heard. Those are like $20 for a set of 4... I assume you get what you pay for.
                  • 7819
                  Re-read this:
                  Marty is showing you who you can trust. Georgefix is the ONLY one on ebay I trust for parts, as he lets you know about them. $100 for a set of four is minimum for good carb boots.
                    • 2011
                    Ebay is a good source for parts. It's a huge source for used parts. If you are looking for something in particular, you could post it here and I could help you.
                      • 813
                      Stick with the eBay seller Georgefix for fuel system related parts, he has a good reputation for selling good quality stuff on several different model repair forums. Last I looked he had Mikuni branded carb boots for $65.
                        • 2011
                        LAB3 is right. I just picked these up from Georgefix's eBay store for $107.39 for a job I am working on.
Name:	s-l1600 (3gf).jpg
                          • 813
                          Georgefix also has a set for $35 that he's claiming last 15 years, based on his reputation I'd be willing to try them.
                          Earlier this winter both he and this seller had these listed, touted as being "genuine Mikuni" $75 a set in this case.
                          https://www.ebay.com/itm/381857847133
