Heads up! Affordable floating disc rotors
    • 837
    After looking over the pictures that DEEBS posted about replacing his front brake rotors I took another look at the pricing. Seems to me I remember EBC rotors going for about $225 each and sure enough they're still awfully expensive. Then THESE popped up for only $150 a PAIR! Looks like I'll be in for an upgrade soon at this price.
    The center part of these looks kinda "Raw" being a simple piece of stamped steel but like my favorite sticker on my bike says "Telling a man his bike is pretty is like telling him his dick is cute"
    In-Stock Replacement Parts for Yamaha | 5G9-25831-10-00 5G2-25831-10-00 2H7-25831-00-00 10L-25831-10-00 SR 500 XJ 550 XJ 650 XJ 750
    • 2057
    Put a few miles on them. Still breaking in the new pads. I like them.
      • 837
      Have you seen replacements for the part that wears to go with these? They'll probably go a good long time but at some point they may need to be swapped out.
        • 2057
        LAB3 I think for the price they are disposable (like most rotors). I'm sure they will last for the rest of my life. If I have any issues, I will report back.
        • e30 gangsta
          • Mar 2016
          • 142
          • Lone tree, Colorado
          Damn these look cool! I might have to upgrade to these, the original rotors just don't look as nice!
          80 XS1110 SG, RD400
          • e30 gangsta
            • Mar 2016
            • 142
            This also got me thinking. Anyone know of a rear rotor that's also drilled that we can purchase new that doesn't cost an arm and a leg?
            80 XS1110 SG, RD400
              • 2057
              All three rotors are the same. I bought three. I will do the rear rotor install soon with a rebuilt caliper/black stainless line and post pictures.
                • 837
                Deebs has it right, you can order a single disc on that site. I'm planning to use the best one of my two front discs on the rear since my rear needs replaced but not necessarily the fronts
                • e30 gangsta
                  • Mar 2016
                  • 142
                  You guys are geniuses! I will order all three then. It looks amazing!
                  DEEBS11 you running the rotors with no lock washers and it works fine?
                  80 XS1110 SG, RD400
                    • 2057
                    Good eye, e30. Lock washers and rim locks are a thing of the past. I use Locktite blue on every nut and bolt in my restorations. Never had a problem. And as I said before, I don't build coffee table bikes. They get ridden across country all the time. (My 80 KZ in this case. No lock washers as you can see in the picture.)
                    Click image for larger version  Name:	Alaska021.jpg Views:	0 Size:	170.8 KB ID:	879297
