XS11 carb fuel T’s replacement
  • jkorn
    • May 2003
    • 188
    • Wickenburg AZ
    I think it’s finally time to replace the fuel supply T’s on my carbs. I’ve dismantled the carbs multiple times, but I’ve never separated them from the rail. Seems a bit doubting what with the linkage between them and all.
    I’d appreciate any words of wisdom before I tackle this issue. Both taking them apart and then back together.
    I’m thinking I only need to remove carbs one and four from the rail.
    Thanks Jeff
    Jeff Korn
    Original Owner 79XS1100 E
    There's nothing tricky about putting them back together, especially compared to V4 carbs.
    There is just the spring loaded tabs on the butterfly shaft, and the choke rod. Just make sure you capture the two little springs and two little ball bearings balls when you remove the choke rod.
    You should expect to have difficulty getting the big screws out of the rail. You can use vice grips on the perimeter of the screws, and then go the hardware srore and replace them with nice stainless steel screws.
    • jkorn
      • May 2003
      • 188
      • Wickenburg AZ
      Thanks Mike.
      what about the carb synch screws? Would be nice to have them back to almost the same as before.
      Jeff Korn
        Most of the parts can be found, if you need them. Take the carbs apart one at a time, and keep all the parts to the carb together. DO NOT mix part! I would buy the new seals for the throttle rods and replace them while you have things apart. It's a pain, but worth it with how many years are on the rubber that is in there now. Hard part about it is the throttle plate screws, as they are split so they can't back out. You can use a dremel with a cut off disk to get most of the split part of the screw removed before trying to pull them.
          The carb sync screws won't be disturbed at all when separating the carb bank.
            ^^ + Yes, sync screws don't need to be turned for disassembly/assembly. The sync tabs are held in place by a spring against the adjustment screw.
            If you are worried about changing the idle mixture screws, you can count the turn to lightly seat them, then put them back to the same number of turns after cleaning.
