80 XS1100 ignition
  • Efesdark
    • Feb 2024
    • 1
    80 XS1100 ignition
    In addition to the hot and steamy webcam porn videos, we can also take breaks to laugh at some of the cheesy dialogue and plotlines in some of the professional porn films. Sometimes it's nice to not take things too seriously and just have fun with it.
    Horny webcam babes ready to spread those cheeks for real intimate dp play. Watch tight bums get worked live! Hot dp action where you call the shots, live and uncensored. 💣
    https://pornlive.fun/videos/20443/se...g-ass-livecam/
    🎥 Unique collection of leaked and user submitted webcam porn clips and live sex movies. Welcome to the best webcam sex tube all over the Internet. - WebcamPorn.online
    • 2010
    Did you still have the ballast resistor installed when you measured resistance? A 3 ohm coil should work in place of a 2.5. The circuit would actually run cooler. You would not want to drop resistance as that could burn the circuit because it's closer to ground.
      • 813
      Originally posted by Efesdark
      Recently bought a 82 XJ1100 pickup plate, rotor and TCI with hopes of trying to replace the ignition on my 80 XS1100 and do away with the flexing pickup coils wires.
      According to the specs that I found the XJ1100 ignition coils should check out at 2.5 ohms of resistance on the primary side with a 10% variance being acceptable. The XS coils are 1.5 ohm so needless to say they won't work with the XJ setup.
      My question is, where do I get 2.5 ohm coils other than finding used XJ coils? Will 3 ohm coils work? I'd like to use Honda CB750 coils or something similar so I can swap out the HT leads when needed. Any guidance on this would be appreciated!
      So, why did you copy/paste one of my posts from the XJ site as YOUR first post?
        • 2010
        Eliminating the ballast resistor (on a 1978).
          • 813
          As mentioned, this was a cut/paste job of one of my posts on an XJ forum. I've got a set of 3ohm Honda 750 coils on my XS right now, still have yet to attempt the rest of it.
            • 8891
            Yep, as mentioned, 3 ohm coils will be fine, just bypass your ballast resistor.
