Headlight warning lamp always lit
    My headlight warning lamp on the dash is staying on despite my headlight working just fine. A couple of weeks ago it came on and it was obvious why, the connector going into the fairing had come loose, after plugging it back in the warning lamp has stayed lit. Any ideas what I'm looking at here?
    Maybe try bypassing the RLU and see if anything changes. I'd also check the ground to the fairing.
      I'll probably get a chance to go over it with a fine toothed comb either today or tomorrow since I'm in a good spot to dig into it. Never did do the customary "Go over every connection and clean it" routine so that's on my agenda.
      PS: Found a reasonable deal on a used XJ ignition system (pickups and CDI) just last night, should be here next week, fingers crossed!
        Turns out that the connector coming off the fairing had nothing to do with it at all. By coincidence the low beam portion of the headlight bulb is burned out!
          Ahhh, so the RLU was actually doing it's job, shifting the current over to the other filament. Sweet.
          • JonnyO
            • Oct 2020
            • 229
            • Sun City West, AZ
            Good for you! That's great. I HATE when I over-analyze something when it turned out it was something ridiculously simple in the first place.
            lol
            ( I used to type GFY! until someone pointed out it had other connotations. lol )
              lol
              Oh believe me, it was over analyzed due to the suspected cause/effect non-relationship.
