Front fork identification
  • UkeeTiki
    • Jun 2022
    • 11
    • Ucluelet, British Columbia Canada
    Weird Harold... I love it.. getting closer now, current forks have the air valves mounted on top and at a 45 degree angle as the parts diagram displays. other than "right fork outer tube" appears to be without the "weird Harold" . makes me wonder if it was just the one "outer tube" [right] was replaced from the say xj650. Click image for larger version
ID:	875609 Click image for larger version
      • 8800
      What would really help to identity would be to measure with a caliper the diameter of the upper stanchion tube(s), XS11 tubes should be 37MM.
      • UkeeTiki
        • Jun 2022
        • 11
        37mm definitely confirmed with brandy new digital calipers. New clue with brake pads that were up front are different style that was on rear (left pads)
          • 8800
          37MM would be 1100 stanchions. The rear caliper is supposed to be different than the front, with the non tapered normal type pads.
          Still a mystery why the right side has no caliper casting.
