Cylinder Boreing and Honeing
  • Jmharrisjr
    • Jul 2023
    • 2
    Hey everyone. I'm looking for a machine shop to bore out the cylinders for me to the 72mm oversize to refresh my engine. Are there any good machine shops in the Maryland/Delaware area? I've seen a few but they are asking 150 or more per cylinder. Is that normal?
    Contact this guy.
    https://www.ebay.com/itm/30188816854...sAAOSwZ8ZW2Lu8
      Make SURE whoever does the job puts a chamfer on the bottom! It makes a big difference when you go to insert the pistons and rings. I have a set of bored jugs that it was not done to. I have not tried to put them on yet, but I will be looking at doing that BEFORE I assemble the engine.
      • XJkid
        • Jun 2003
        • 281
        • Elk Grove, Ca.
        Is the rebuilder selling the same item for xs AND xj?. I understand there is a valve size difference between the two.
          I believe he changes the tooling to adjust for most common sizes of valves which would include the XS and XJ models. I am to understand the service uses your existing valves as long as they are in good condition. I have never used this service but he has good feedback on eBay. I use Eastwood in Somers CT. They did my KZ1000 head a few years back.
ID:	874760 Click image for larger version
ID:	874761 Click image for larger version
