I am figuring out the ignition switch on my 1980 xs1100 special. I know it is a two position switch but there are 4 wires. Can someone explain what the four wires are. I don’t see them on the wiring diagram and was wondering why 4 wires are needed for a 2 position switch. Thanks
Ignition Switch
Tags: None
Red: Power into the switch
Brown: Power out of the switch to the fuse panel
Blu: Power to the tail/running light
Other wire: Power to the emergency flashers
It is actually a 3 position switch, the far left position (key needs to be pushed down while turning) is for running/parking light/steering lock.
The earlier 78-79 models had a 3 wire switch as these bikes did not have emergency flashers.Last edited by bikerphil; 07-19-2023, 03:41 PM.2H7 (79) owned since '89
If the switch is the stock switch, it's a FOUR position switch. Going from "run", counter clockwise, 1. Run 2. Stop 3. Lock, with front wheel full left or right 4. Park light, turns on tail and front running lights for night visibility.Ray Matteis
XS1100 SF Bob Jones worked on it!Comment
Got it. So if I’m getting a universal ignition without lock I would need a 3 position switch 1.Off 2. Parking/emergency 3. Run?Comment
I would replace it with an OEM switch myself. If you want just the off/run, that is OK as well. You will need to look at how the emergency flashers are wired to still use them. You don't "need" the park light feature.Ray Matteis
