Cylinder head compatibility
  • Restless
    • Mar 2023
    • 12
    Is the 3H5 cylinder head compatible with a 2H7 motor? The cylimder head I ordered comes with cams, valves, and shims already installed.
    • 2104
    No, but that's the short answer. Need more info to elaborate.
    • Restless
      • Mar 2023
      • 12
      What info do you need
        No, don't do it, the compression will suck unless you change the pistons too, if it was the other way around then yes.
        • Restless
          • Mar 2023
          • 12
          Well here is what I'm dealing with.
          1. 3H5 motor with a destroyed piston and rod as well as a useless the cylinder head.
          2. A 3H5 cylinder head on the way via ebay with valves intact
          3. A 2H7 motor with all good pistons but no cylinder head
          So I'm trying to figure the best way to get a complete motor. If the 3H5 motor will not play well with the 2H7 cylinder head then do I have to split the case to replace the rod that holds the piston?
          • e30 gangsta
            • Mar 2016
            • 142
            • Lone tree, Colorado
            It will be fine. Just not as much compression. I run a 81 head on my 78 runs fine.
            80 XS1110 SG, RD400
            • Restless
              • Mar 2023
              • 12
              I'm curious what the long answer is. If it is just compression loss I am going to go for it. Is there something else i should be aware of?
              Thank you e30 gangsta. I was startimg to feel hopeless
