Cleaning rust with aluminum foil
    • 813
    I know what you're thinking "How the heck is THAT going to work?" but it does! Granted, you probably don't want to try this on a pristine surface but if you're like me and prefer the "Honest Survivor" look then it does a good job, especially on pipes.
    This speedy Instagram cleaning hack may sound like a spoof, but it is an old cleaning trick professionals swear by
    • 2138
    Some folks like to dip the foil in Coca Cola because the phosphoric acid helps to remove the rust and leaves a phosphate barrier.
    I tried it on an exhaust system. It worked for me, but it didn't seem like a miracle.
      • 813
      I wouldn't call it a miracle either, the cheapo Turtle Wax chrome cleaner works just as well but foil will often flake off and get into pitted areas making it look a bit better when done.
