Standard vs. Special Front End
    • 3918
    Couple Quick Questions: Is the calipers on the Specials and the Standards the same? If not, can I use Special Calipers and Mounting Brackets on a standard front end? What year has the slotted front rotors? Can I use a slotted rotor on the rear? I have a set in my garage I'll be using for a project. Can I use a 15.8mm piston Master Cylinder with stock brakes?
  • Tonyxs11
    • Oct 2022
    • 271
    • Cumbria UK
    the callipers are not interchangeable. you would have to change the whole front end
      • 1818
      The slotted rotor started around 1980. The rotors are interchangeable for different years. I believe you must keep fronts and rears separate. They may not be interchangeable.
        • 3918
        Did any Standards use slotted rotors? I have a front end with slotted rotors, but can't remember if it came off a Standard or Special.
          • 774
          Could the slotted rotors be something that where available in the aftermarket?
            • 8797
            The 81 Standard (Venturer) has slotted rotors. You can put a front slotted rotor on the rear as long as it is a right side rotor.
              • 1818
              Phil is right. The slots are directional.
              • Tonyxs11
                • Oct 2022
                • 271
                • Cumbria UK
                does it really make that much difference though ? ive seen many bikes with the front disc's on the wrong side, slotted and curved drilled and still do the job. one of my 1200 bandits had the front disc's on opposite sides for a long time until i noticed them !!!!
                  • 774
                  Does it make a difference which way they go? Probably does on some level known only to the minds of those that design such things. Hey, I'm one of those kinda guys who's not against breaking the rules but at some point you have to accept that the folks who design things have more experience and knowledge than I do! Will it still work? Probably. Is it set up for optimum capability if I do it "Their way"? Yes. Does it really matter? Give it a try, you probably won't know until you do.
                    • 1818
                    According to rumors not read fact, the thought with grooves or holes in rotors is to disperse water in heavy rain and snow. The question of pattern direction would depend on possible rain/water "fling" off the rotors in motion in either direction. May not matter but they are certainly balanced to go in either direction.
                      • 1818
                      Also, I do not believe the rotor effects the speedometer drive like an EVO Harley. Some bikes are notched in the rotor for the drive.
                        • 3918
                        Looks like I got lucky: Greg says it's a Standard front end.
                          • 7941
                          For the record, the XS1100 standard has a front suspension made by KYB. The axle is mounted on the bottom of the sliders. The Special front suspension was made by Showa. The axle is mounted on the front of the sliders. Fenders, fork braces and calipers do not interchange.
                            • 7765
                            And yes, the holes/slots DO make a difference in the rain! I had my first '78 rotors drilled by a machine shop after blowing through a stop sign in the rain. Always stopped when needed after that.
                            • Tonyxs11
                              • Oct 2022
                              • 271
                              • Cumbria UK
                              yep, bang on Ray
