float valve
    • 2074
    float valve
    So been cleaning the carbs on my 80 SG and everything is being looked at closely as I clean them. The float valve seats-# 2 carb the seat just dropped in. I took it out and looked at the O-ring and decided to replace it as it never has been replaced. I took a pick to remove it and the o ring broke in 2 pieces so it was time. I had a brand new O-ring I bought from partszilla and installed it. This time it did not go in as easy. What is the preferred method to install the new float valve seat?
  • Tonyxs11
    • Oct 2022
    • 271
    • Cumbria UK
    yep, the O rings go hard and brittle, then they leak giving the impression its the float valve.
      • 2074
      I bought spare float valves from georgefix on E- bay. The current ones are in good shape.
        • 2074
        Maybe I could put the float valve seats in the freezer for a bit to shrink the O-rings?
          • 798
          Putting them in the freezer might shrink them a couple of thousands of an inch, that's it, not to mention making the oring harder and less flexible once it touches the metal. It seems counter intuitive but in this case it's a matter of "brute force and ignorance" to get the job done. You could get one part of the oring onto the widest part of the barrel and hold it there with your finger and use something rounded like a pin with point ground off to help pry it on. A little bit of oil might help too but it would make things more slippery for holding the part of the ring you want to stay on the widest part. I've used a jewelers screwdriver before but don't tell the purists!
          • LenB
            • Nov 2020
            • 159
            • Winnipeg, Manitoba, Canada
            I've had success by wiping a light layer of Vaseline/grease on them and they slide right in. Whatever lube you used dissolves harmlessly.
            1980 XS1100G (one owner-me)
            1984 Honda VF750S V45
            Owned - 1976 XS750D
            Owned - 1972 Honda CB750
            Owned - (unknown year) XS650
              • 1972
              I always use O-ring lubricant when installing a fit like that. A dry fit could tear the O-ring.
                • 2074
                DEEBS11-like that idea of the grease. LAB3-I use no tool to get them in. Just asking for trouble. I did get O rings last year on E bay that were not correct They wouldn't work even with a drop of light oil on them. The seller said I thought they were correct guess I was wrong.
                • Tonyxs11
                  • Oct 2022
                  • 271
                  • Cumbria UK
                  a drop of engine oil will do, they just drop in, done it many of times.
                    • 1964
                    When I am at that stage to put those in I always have a can of carb cleaner spray sitting there so I just spritz them and the seat with that and then quickly slide the seat home. The carb cleaner dries up quite quickly.
                    • Tonyxs11
                      • Oct 2022
                      • 271
                      • Cumbria UK
                      carb cleaner is not good for rubber !!!
                        • 1964
                        with no more time then it takes to get the carb back together and submerged in gas that particular o ring does not suffer from a small amount of carb cleaner.
                        • Tonyxs11
                          • Oct 2022
                          • 271
                          • Cumbria UK
                          I would still prefer to use a drop of oil though
                            • 1964
                            I found an interesting article concerning carb cleaner vs brake cleaner. Not that I am suggesting brake cleaner for anything, but cleaning brakes. Was a good read. Carb Cleaner Vs Brake Cleaner - Can You Substitute Them? | FixandTroubleshoot
                            • Tonyxs11
                              • Oct 2022
                              • 271
                              • Cumbria UK
                              interesting read, but ive also read that carb cleaner should not contact rubber in carbs by other experts, difficult who to believe ????????
