carb top screw size
    • 2117
    carb top screw size
    Does anyone know what size screw to attach the top to the carburetor? Metric screw maybe M 4? Takes 16 screws-need extras.
  • jkorn
    • May 2003
    • 188
    • Wickenburg AZ
    Take old one to hardware store and buy new one with an allen wrench head. Much easier to work with.
    Jeff Korn
    Original Owner 79XS1100 E
    • jkorn
      • May 2003
      • 188
      • Wickenburg AZ
      I replaced all of mine, the old ones, the screw slots were getting worn out.
      Jeff Korn
        • 2117
        jkorn-would be so easy but having mobility issues and easier to know size and order it online. My knees are shot and cant really walk good.
        • Tonyxs11
          • Oct 2022
          • 271
          • Cumbria UK
          classic sign of the wrong screwdriver used, JIS is the way to go
            • 2117
            I guess people don't read the post-unable to physically go to the store at the moment.
              The bolt size is in the last digits of the part number.
              • jkorn
                • May 2003
                • 188
                • Wickenburg AZ
                Let me dig thru my parts and see what I can find. JK
                Jeff Korn
                • jkorn
                  • May 2003
                  • 188
                  • Wickenburg AZ
                  I believe I bought these, but the link is to Amazon.
                  https://www.amazon.com/Socket-Screws...07F8R2H99?th=1
                  jk
                  Jeff Korn
                    • 2117
                    jkorn-thank you!!
                    • jkorn
                      • May 2003
                      • 188
                      • Wickenburg AZ
                      Your welcome. The hex head bolts are so much easier to use and I just can’t count the number of times I’ve had those carbs apart. Jeff
                      Jeff Korn
                        I've had a problem using them and others have as well, it's easy to put too much torque on them and strip out the threads so be careful!
                          I agree it is much easier to strip the threads out of the carb. One thing I have found with the hex head bolts is that if you buy them a bit longer then OEM philips (JIS) headed screws that you have much less chance to strip anything out. More to work with.
                            • 2117
                            Years ago I bought the Allen head button screws through crazy steve I believe a moderator on here. I also have JIS screwdrivers. Not everyone is ham fisted on here.
                              • 2117
                              Jkom-screws came in and was able to replace 1 so far. Thank you for that link.
