Switching to resistor plugs
    The bike has gotten a little rough to start when warm and sure enough two of my resistor caps are reading WAY high. Since it's getting harder to get non resistor plugs I'm thinking of replacing the caps with non resistor caps and resistor plugs. From what I've gleaned the circuit requires 5k ohm of resistance and the NGK BPR6ES should do the trick. Going to replace the caps with NGK LZFH non resistor caps and my question is did I figure this out right? If not what have I missed? TIA!
    You should be good to go! I did that on one of my bikes a few years back, and it was still running well when I sold it.
      Did the same swap on an old Suzuki GS about four years ago for the same reason, non resistor plugs where getting harder to find. I'm pretty good with electrics in general but getting a thumbs up from another experienced rider is always a good practice when breaking away from the "norm"
