Jacking points
  • eroellig
    • 229
    • Arkansas
    Jacking points
    OK, so I have a motorcycle jack that I picked up for the teardown this winter. After I rolled it up to the bike last night to check it out, I see that the exhaust system hangs lower than the frame.
    How do you guys jack up your bikes so you can take the front end apart?
    Eric
    Eric Roellig
    1980 SG w Windjammer V & KG hard bags
    **Very first bike**
    Current condition: Running!!! Lead, follow or get the #^%# out of my way!!!!!!
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    Blocks of 2x4's on the jack, between the pipes. Frames are hard to put jacks or wood under. Just put the wood blocks on a level part of the oilpan.
    "But... then you'd be jacking the bike up by the engine!"
    Yeah, so... the engine is 80% of the weight of the bike. Everything attaches to the engine.
    • randy
      • Dec 2003
      • 4521
      To jack up the front, I use an auto floor jack and a block of wood under the center frame member between the pipes (near the cam tensioner)
        • 5061
        Me too. I don't know if I could trust the stability of a motorcycle lift jack.
        • Czekus21
          • 1069
          • Keosauqua (Southeast) Iowa
          I use a block of wood and the trusty Wal-Mart 2 1/2 ton floor jack.
          You can also use the center stand and ( with some help ) teeter the bike rearward and have your helper ( or your self ) place a block of wood and a jack stand on the front engine mount bolt.
          Supported rafters and a few ratchet straps work to. Takes a little bit of time and is very unstable. Hmmm,,. I have know idea how I know that...
          S.R.Czekus
          1-big XS patch
          1-small XS/XJ patch
          1-XS/XJ owners pin.
          Just do it !!!!!
          • randy
            • Dec 2003
            • 4521
            Forgot to mention,
            While i have the front wheel off, the floor jack enables me to lower the front far enough to remove the rear wheel without messin with the fender
            • RiskyBusiness
              • Mar 2003
              • 174
              • Richmond, Virginia, USA
              I use my cycle jack to lift the bike by the 2x4 on the oil pan method mentioned above. I then use a jack stand in the front and a couple of blocks in the back to hold it there. Sometimes I just use the center stand for the rear and a jack stand in the front. Either way, I jack up and then remove the jack. Just like with a car: I don't find a jack stable or convenient to hold the bike.
              1979 XS1100 Special with 81 carbs
              • eroellig
                • 229
                • Arkansas
                Thanks for the ideas..
                Eric
                Eric Roellig
                **Very first bike**
