ELDER's LED flasher
    • 8891
    If you're going to use a standard electronic flasher (aka digital) you want a 2 prong, and don't use the yel/grn wire in the harness plug. Of course, no self cancel.
      • 8061
      I have one of these ELDR units. It was plug-n-play for me. (80 Special). My cancel function is intermittent. I assume that’s the pick-up in the speedometer.
      • dpotter58
        • Aug 2004
        • 1865
        • Southern Maryland
        Not a ground https://imgur.com/a/wIgrJnQ
        after all the frustration, i changed the ground wire to a spot on the frame.
        that screw on the plate the fuse box is on isn't grounded.
        1980 LG
        1981 LH
          • 8891
          Lol, too funny. Glad it's working now.
          I used the negative screw terminal on the auxiliary fuse box.
