I need a new battery in 2022 for a 1980 XS11
    • 7861
    My battery is done. It might be 10 years old. It has a Deka AGM in it. Apparently, I can't get one of those. How about a Yuasa AGM? I can't find that either. How about an AGM that fits properly in the hole and has the proper CCA? Have any of you been through this lately? I want a quality battery. Thanks.
    • 2053
    I'm not sure if you would perceive this as a quality battery, but I have this one in some of my bikes; the longest for 6-7 years, and I am completely satisfied with them. They are my first choice these days.
    https://www.batterysharks.com/Yamaha...hoC7mwQAvD_BwE
    The shipments arrive at my house within 2-3 days after I place the order with this vendor.
    NOTE: I generally stopped using trickle chargers after I went AGM. I might top them off for a few days with the trickle charger halfway through the Michigan winter, but I am not religious about it.
      • 7861
      Mike,
      The battery in your link is the correct dimensions?
      I will have to check the date code, but I got a lot of years on the Deka. The only charging it got was from the bike’s alternator. No matter. It seems Deka doesn’t make out battery any more.
      Thanks for the link, Mike.
        • 2053
        Yes, dimensions are same as the original OE battery.
        Battery terminals have the correct LH/RH orientation.
        • jkbrand
          • 1
          I have a 1980 XS1100 Midnight Specal and recently ordered and installed this AGM from Amazon. Same size, same post configuration as stock; not sure, however, about CCA matching. Free delivery if your a Prime user.
          https://www.amazon.com/dp/B01BX0VU4U...roduct_details
            • 7861
            I want another Deka or Yuasa AGM battery. I guess I have to get over it.
            I did once get 9 years out of an AGM battery from MiKe’s XS! That was in my XS650.
              • 2070
              I have been lucky with the AutoZone AGM battery for a few years. I use that in my 80 SG and also my 99 ZRX 1100. Better than Walmart.
              • SouthernGrey64
                • May 2016
                • 40
                • Marietta, GA.
                Marty, I too just purchased the Sigmas Tex STX24HL-BS battery from Battery Shark that Radioguylogs recommended above. It is a replacement for one just like it that I purchased in May of 2015 when I was restoring my SF. Got over 7 years out of it. Got what I thought was good service out of a relatively inexpensive battery. Stays on a BatteryMinder Plus, Model 12117TC, that I got from Northern Tool when waiting in the basement for the next ride. Going to Barber Vintage Weekend October 6-9 with 3 buddies. Hope to see you there.
                1979 XS1100SF
                Original Owner-purchased January 1980
                  • 1895
                  1980 Yamaha XS1100 (All) 1100CC Motorcycle Battery at Batteries Plus
                    • 7861
                    Thanks to all of you for the responses. If I want a face-to-face customer service, I have NAPA, O'Rielly's, Interstate and Batteries Plus.
                    I did a little research and learned that the appropriate NAPA or O'Rielly battery, are made by East Penn Manufacturing. They make the Deka brand. That said, and both NAPA and O'Rielly are close by. I'll pick one of those. Thanks again!
                    • Tim
                      • Sep 2022
                      • 6
                      • West Texas
                      With the supply chain shortages often times Yuasa is not available so we go with power max from Parts Unlimited or Fire Power from WPS. We are dealers with the major parts supply houses and due to the covid shut down (another story), supplies in many areas have been limited
                        • 7861
                        My Deka battery lasted from August 2015 to August 2022. I’ve owned several of them. NAPA batteries are the exact same manufacturer. So, I walked into NAPA and ordered a battery. I picked it up 24 hours later. The price was very competitive, plus they gave me a veteran discount. If it fails, I have a place to hand carry it.
                        I greatly appreciate the responses in this thread. Thank you! I took my Eleven Special on a 40 mile errand yesterday and stretched it to 100 miles.
                        BTW, the AGM battery for this bike is also available available from O’reilly for about the same price and it is also made by East Penn. Click image for larger version
