Xj1100 octopus rebuild
  • Selmer
    • Feb 2022
    • 2
    Does anyone know if I can get a rebuild kit for the octopus on my 82 xj1100 maxim, or if it will just need to be bypassed.
  • wayneshrt
    • Mar 2008
    • 34
    • kingsport, tennessee 37660
    Babbittsonline.com Diaphragm Assembly 3H3-24520-01-00 $151.99, or buy used on ebay for about $60, or you can replace with 2 brass "T" fittings. I have traded for a few that it was left off. I try to put them back original.
      • 7830
      or try georgefix on ebay, https://www.ebay.com/itm/36200130540...EAAOSwZBphHFJR I've had good luck with most of his products. The K&L kits work on the petcocks, but the carb kits are only good for gaskets, as the jets are the wrong size.
        • 2007
        Way overpriced. The entire petcock and octupus rebuild kits can be found on ebay almost daily at below $25, as Ray has pointed. out. One thing to watch out for are the o rings to be used to seal the petcocks onto the fuel tank. They are generally just a tad too thin and don't seal well. I always use larger ones to ensure a good seal.
