Mystery washer
  • XJkid
    • Jun 2003
    • 281
    • Elk Grove, Ca.
    Mystery washer
    Putting in new (modified) gears and found this on the clutch shaft when I went to put the clutch pack back on. I took apart my parts engine to see if it had one. Nope. I have a service manual and on the gear and clutch explosion do not see anything like it. I had carefully put the gear string back together according to the manual, so I don't think it's a leftover plate washer from the trans. It does fit nicely on the clutch shaft, though.
    Maybe someone installed a washer for better dog-in-slot engagement. I have never considered modifying the transmission because none of my 4 XS11s had the problem.
    • XJkid
      • Jun 2003
      • 281
      • Elk Grove, Ca.
      Well, maybe you are just not riding hard enough!!!
        No, he is just shifting the bike as he should! When you try to "speed shift", or "power shift" is when they break.
