Broke off terminal in stock fuse panel
  • LugNut
    • Feb 2021
    • 73
    • Avilla IN
    Had to pull 30 Amp original fuse from 42 year old bike...so you can guess what happened....
    Quick/easy way to get this to work? Just wanted tobstart to run gas+StaBill through carbs for winter storage...while cranking headlight and meter were off then on then off...pulled side cover and fuse was bad. When i grabbed it gently the one side of prong/holder snapped off clean. See pics.
    I know how to fix it correctly (have new fuse block and all the goodies)....BUT what is the best fast way to fix it so i can ride it a tiny bit and put away for winter?
    • 5073
    May as well make a little time to get that new fuse block installed…
      • 1987
      same thing I suggested, however it turns out he is not wanting to keep the bike and will leave it up to whoever purchases it to invest in and do the proper fix.
      • shutchis
        • Oct 2004
        • 191
        • Deer Park, TX
        Buy an in-line fuse holder at an auto parts store. Attached the leads to the fuse block wiring. Soldering the connection is probably best solution. By sure to purchase a fuse. This is a quick and easy solution and should get you rolling. You could use alligator clips and jumper wires without a fuse but it's not my recommendation.
        '80 XS1100LG Midnight Special
        Looks like an '82 Maxim, Fuel Injected
        '82 XJ1100J, Fuel Injected
        Stan Hutchison
