Did you keep the octopus, or ditch it?
  • tommystinson
    • Aug 2003
    • 425
    • Albany, NY
    Wanted to test my impression that most people ditch the octopus and just run a couple of fuel lines.
    19
    Kept it. Was working fine.
    21.05%
    4
    Kept it. Needed repair.
    31.58%
    6
    Ditched it. (insert your motivation here)
    47.37%
    9
    2010 Kawasaki Z1000
    1979 SF: Millennium Falcon, until this Saturday
  • shutchis
    • Oct 2004
    • 191
    • Deer Park, TX
    I ditched it. It's complicated. If the vacuum diaphragm fails (leaks), then it pulls gas into the #2 intake cylinder. Not good. It's better to keep things simple, learn to close the petcocks. Problem solved.
    '80 XS1100LG Midnight Special
    Looks like an '82 Maxim, Fuel Injected
    '82 XJ1100J, Fuel Injected
    Stan Hutchison
    • Bax
      • 344
      • Merrimack, NH
      I definitely kept it when I had my carbs. Now with the EFI build it is not needed.
      Bax
        Long gone, but now I use a Pingel inline vacuum valve, only 3 hoses connect it. High quality. It sucks if you have to worry if you turned off your fuel valve(s).
        • dpotter58
          • Aug 2004
          • 1866
          • Southern Maryland
          I've had several and never got rid of them.
          1980 LG
          1981 LH
            When refurbished correctly and routed correctly it is a good safety device. I would never get rid of it. Of course I have a habit of always turning my petcocks off anytime I stop and park the bike. I have had more problems with leaking petcocks then malfunctioning octi.
              Many of my bikes have had manual petcocks, so I am used to turning them off.
              I don't like that big wad of hoses and I have had trouble with vaccuum-actuated petcocks after rebuiling them.
              • red bandit
                • 970
                • central michigan
                The Standard has vacuum petcocks. Two of them. I never shut mine off. My 4 wheeler has a manual petcock, I never shut it off. Lawn mowers don't have a petcock. Keep your carburetor float needles working properly and you won't have any problems. MHO.
                79 SF parts bike.
                  • 735
                  High up on the list of things to do on any of my restorations is to pull the carbs for a good cleaning and immediately ditch the octy. I’m a believer in keeping it simple. Two fuel outputs to two fuel inputs. Yes, remembering to shut off the petcocks is a PIA but I figure that if my aging mind can’t handle that simple task, then maybe I shouldn’t be on the bike at all!
                    It's not that hard to fix. It has a function. My XS650 has a vacuum petcock that works the same. In 38 years, I've had no issue with it.
                    • tommystinson
                      • Aug 2003
                      • 425
                      • Albany, NY
                      While not a huge sample size, I'm surprised at how many people kept the octopus. For me, it was a variable I could easily remove from a non-running bike. Extra vacuum lines and fuel lines? Keep it simple, stupid. Today, if I had a friend with an XS, I might consider recommending he keep it and make it work but I don't know what a rebuild kit costs. FWIW
                      2010 Kawasaki Z1000
                      • Banshee's Veil
                        • 104
                        I kept mine, rebuilt the valve and used about 5 ft of tygon tubing along with brass t fittings. Works great.
                          The octopus is an abomination! I would ditch it.
                            Yesterday, I pulled my SG out from where it had been resting for two months. I reached down to turn on the fuel, and to my horror, the petcocks were both ON. First, I checked the oil and found the level was right where it was supposed to be. I moved to PRIME, then back to ON. It started right up just fine. My vacuum shutoff works and it's my intention to keep it that way. Not only is it a safety device, but it saved me from having to depend upon four float valves to protect my engine. I fail to see the problem with it. A rebuild is simple.
                            As an aside, I've owned my XS650 since new. The vacuum petcock works as well now as it did then and I've never opened it up.
