Sudden loss of spark
  • scott0757
    • Jun 2007
    • 130
    • Syracuse, NY
    My 1980 XS100SG ran great when it parked it a few weeks back. Today I went to ride and would not fire. Not spark at the plugs. Seems odd but al the plug caps seem to have open resistance...cannot get a coil reading unless i pull the caps off and probe the leads directly. Primary coils read correct. Balkst resistor voltage onky reads about 5 to 6 volts and I read on her ut shoukd read 12. New battery. Going through everything...not a clue so far.
    any ideas? Emergency Off switch? Thx.
    ps. New 5ohm caps onn order
    Past Rides:
    1969 OSSA 250 Pioneer
    1979 XS650 Special
    1978 Honda CB750K
    Current: 1980 XS1100SG
  • Bax
    • 344
    • Merrimack, NH
    Broken strands inside of the insulation on the pickup coil wires are a known spark killer problem.
    ----Bax
    • scott0757
      • Jun 2007
      • 130
      • Syracuse, NY
      That's next on my checklist. Thanks
      Past Rides:
      1979 XS650 Special
      1978 Honda CB750K
      • scott0757
        • Jun 2007
        • 130
        • Syracuse, NY
        Checking the pickup coil leads. One thing i found was the vacuim hose had split znd popped of the carb vacuum tube.
        My colors are not what my Clymers diagram shows. I am assuming the Y and W stripes are the actual pairs.
        Clymers. Actual
        R/W. R/W
        G/W. G/W
        Y. G/Y
        Y. R/Y
        i measured 730ohms between Yellows and open between the whites. Not sure how I know which coil/wire these white wires go to. Where do these wires normally get spliced to new color?
        Also the wire routes under the case right over the frame tube. Will be fun to find where I need to splice.
        Past Rides:
        1979 XS650 Special
        1978 Honda CB750K
        • Bax
          • 344
          • Merrimack, NH
          scott0757 Check out this guide.
          Bax
            • 1914
            just throwing this out there ... but it could also be your TCI. Have you checked the connections going in and out of that?
            • scott0757
              • Jun 2007
              • 130
              • Syracuse, NY
              Cajun31-
              I checked all connections first, including the TCI's. I have found intermittent pickup coil leads and fixed them and am mid-rerouting that harness under the case and up behind the fuse block. Working my way thru everything. The plug wire caps seem to be a real issue...open resistance. Just strange they all went together. New cap on order. Coil primary tests perfect. Plug side tests good when caps removed. Thx for suggestion.
              Past Rides:
              1979 XS650 Special
              1978 Honda CB750K
              • scott0757
                • Jun 2007
                • 130
                • Syracuse, NY
                Got nice blue sparks on all 4 plugs, even those with what appeared to be open resistance plug wire caps! Go figure. Time to reassemble and test ride. Wonder if the disconnected vacuum advance line could have resulted in stressed coil wires?
                Past Rides:
                1979 XS650 Special
                1978 Honda CB750K
                • Bax
                  • 344
                  • Merrimack, NH
                  scott0757 The flexing pickup wires have long been an issue. Good to hear your spark has returned.
                  ---Bax
                    • 8799
                    Probably too late, but this is the P/U coil wiring breakdown for a 79, may be the same as the 80...
                    • scott0757
                      • Jun 2007
                      • 130
                      • Syracuse, NY
                      Just to confirm what you provided did match my 1980 XS1100SG wiring.
                      Past Rides:
                      1979 XS650 Special
                      1978 Honda CB750K
