Anyone have this happen with led’s??
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    I have no idea why this is happening. Electronic flasher installed, diode in place. I’ve been working on this for a few weeks now, and I thought I had a solution. My rear taillight frame spots are pretty much useless (tabs are pretty much gone), so I wanted to mount some LED’s. I put led bulbs in the stock signals, just to test it, and I have new rear signals to put in once this actually works. However, SWING AND A MISS, EVERY. TIME.
    Edit - I can’t upload a video of it. It CONSTANTLY flickers, yet will dim…but never goes out.
    Eric
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    I put the stock flasher in, and the signals are BRIGHT, as they should be, but don’t flash. I have two electronic flashers - a two prong from Napa, and a three-prong from autozone (novita EP36), but that doesn’t work at all. I’ve tried every combination with the flasher plug and the Napa two-prong plug, and nothing works. I’m going to try the three prong quick…
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    • ERM83
      • Apr 2016
      • 314
      • Lehigh Valley, PA
      Also - only the left turn signal (acewell speedo / tach) stays on. This is beyond me…
      79' SF carbs
      MAC 4-1
      K&N Pods
      Accel 3.0 coils
      Tarozzi fork brace
      TC fusebox
      Picture update soon
        Verify that you have a GOOD GROUND to ALL of the lights! The rear lights had a ground wire that went from the bolt to a frame ground on the stock unit, because of the rubber mounts for the lamps. I'll need to go look at the flasher I'm using, but on my '79 Special the lamps work well, even with the engine not running.
        • ERM83
          • Apr 2016
          • 314
          • Lehigh Valley, PA
          Thanks for the input - I definitely have a good ground! The incandescents worked. I even tried to get a “clean” ground for the rear signals…didn’t work. I’m so bummed…
          79' SF carbs
          MAC 4-1
          K&N Pods
          Accel 3.0 coils
          Tarozzi fork brace
          TC fusebox
          Picture update soon
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            But why would the lights be bright when the stock flasher relay was on there?? One of the many things I’m trying to understand…I know the bulbs aren’t garbage, because they were BEAMING with the incandescent relay. I’m going to try to put my brand new lights in temporarily; see what happens…
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
              • 8962
              The stock flasher is designed for conventional filament type bulbs, it requires a higher load to collapse the circuit. It stays on because the LED's don't provide that load needed, they draw very little power, so the electronic flasher is needed.
              The 3 prong flasher won't work with our systems so put that one aside.
              The yel/grn wire at the flasher is not needed with the two prong electronic flasher, it is for the self cancel feature.
              Try reversing the brn and the brn/wht connectors in the plug and see if that works.
              • ERM83
                • Apr 2016
                • 314
                • Lehigh Valley, PA
                I know this is a stupid question, but should I ground the ring terminal and tap into it with the ground wire on the new rear lights, or can I just straight up connect to the ground wire without the ring terminal?? I’m using (or would LIKE to use) a fabricated “L” bracket to mount the new lights, using the bolt that goes through the grab-bar (12mm, towards the back).
                79' SF carbs
                MAC 4-1
                K&N Pods
                Accel 3.0 coils
                Tarozzi fork brace
                TC fusebox
                Picture update soon
                • ERM83
                  • Apr 2016
                  • 314
                  • Lehigh Valley, PA
                  Update: hooked the new rear LED’s up. They flash, just as weak as the other bulbs did. But now, the fronts don’t work at all. They’ll flash quickly once, then die. The left indicator in the speedo comes on regardless of which direction I push. I’m going to end up wasting a rare 4 days in a row off just trying to get these to work, when I planned on riding. WHY WILL THESE NOT WORK.
                  Again - I’m using new led signals from revival cycles in the rear, stock flashers with led bulbs in the front.
                  here’s the flasher I’m using…would this have anything to do with it??
                  79' SF carbs
                  MAC 4-1
                  K&N Pods
                  Accel 3.0 coils
                  Tarozzi fork brace
                  TC fusebox
                  Picture update soon
                  • ERM83
                    • Apr 2016
                    • 314
                    • Lehigh Valley, PA
                    Now 15 hours into this in the last two days, and NOTHING is working. I think I’m going to say “&#*% it”, and just rewire the entire damn thing with a motogadget unit, which I definitely can’t afford, but I’m beyond tired of this. I have no idea what else to try.
                    79' SF carbs
                    MAC 4-1
                    K&N Pods
                    Accel 3.0 coils
                    Tarozzi fork brace
                    TC fusebox
                    Picture update soon
                      • 8962
                      Do you have another 2 prong electronic flasher you can try?
                      • ERM83
                        • Apr 2016
                        • 314
                        • Lehigh Valley, PA
                        Nope…no one around here sells anything but the one I have. I’m still exhausting options. The weird thing was - as soon as I grounded the rear signals via loop terminals, just like the stock signals, the front signals stopped working. I took one loop off, and one signal started to do the usual garbage that it was doing before. I’ll tell you this - I am never, EVER trying this $&@# on another stock bike with an aftermarket speedo. This is beyond frustrating…usually I can walk away and figure it out the next day, but this has been nothing short of a wrench-thrower.
                        79' SF carbs
                        MAC 4-1
                        K&N Pods
                        Accel 3.0 coils
                        Tarozzi fork brace
                        TC fusebox
                        Picture update soon
                          • 8962
                          So your saying the front signals work normally with the 2 prong electronic flasher when the backs are unhooked?
                          • ERM83
                            • Apr 2016
                            • 314
                            • Lehigh Valley, PA
                            The right front works…sort of. Same flickering nonsense. The left one won’t work at all.
                            79' SF carbs
                            MAC 4-1
                            K&N Pods
                            Accel 3.0 coils
                            Tarozzi fork brace
                            TC fusebox
                            Picture update soon
                            • ERM83
                              • Apr 2016
                              • 314
                              • Lehigh Valley, PA
                              Do I need a diode in the front AND the rear?? I can’t figure out what I’m missing…
                              79' SF carbs
                              MAC 4-1
                              K&N Pods
                              Accel 3.0 coils
                              Tarozzi fork brace
                              TC fusebox
                              Picture update soon
