Hello and greetings from the UK. I purchased a non runner 1980 Yamaha XS1100 Martini that the previous owner had attempted to get running and his version of cleaning the carbs is not the same as mine, I don't think he even realised it had a pilot circuit underneath the screw cap and would only run on full choke. I have properly cleaned them now, all components steam cleaned in a proper cleaning vat, ultrasonic cleaned and lots of compressed air. I have had the bike running and it seams to be pretty good but I am not convinced 100% as I have restored multiple bikes/makes models so another strip down and an inspection of the carb components was decided. What I have noticed if you look at the attached picture is the left side emulsion tube at the top is not drilled through so the pilot circuit is linked when it is fitted, only this one out of all 4 is not drilled and my question is should it be drilled? If not which carb number should it be fitted into as he may have got the parts swapped around and that is causing my issue?
Anyway I cant find anything in my haynes manual so I thought I would turn to this forumn and see if anyone has had a similar issue or discovery.
Thanks in advance
Thanks in advance
