exaust cracked
    If needed.
    https://www.ebay.com/itm/19600683635...Condition=1000
Name:	XS1100 exhaust stainless.jpg
    • speedlimit85
      • Jan 2017
      • 491
      • Gainesville, Fl.
ID:	891535That was exhausting.
      80 G
        Looks good, so they welded it on the bike?
          • 3372
          Exhaust gaskets can be reused successfully. Hold them on the edge with pliers and heat them up to cherry red all the way around. One spot will get red then move the propane torch around and heat it up circularly to red as you go. The whole thing doesn't have to be red at once. Set them down to cool naturally, never had a problem with a leak.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • speedlimit85
            • Jan 2017
            • 491
            • Gainesville, Fl.
            60 bucks on the bike good to go
            80 G
              Yep, I have the same exhaust, fortunately not cracked. Looking at the location of your weld, it looks like by removing the aluminum hanger bracket, there is sufficient room to weld, although very close to where the crossover is located.
