Leaking Carbs
    • 3917
    Leaking Carbs
    For the past year, I was trying to understand my leaking carb issue. Can't count all the rebuilds, GeorgeFix kits, etc. Part of my Spring startup was pulling the carbs for a Triple-clean. Back together, still leaking. Take back apart. Decided to do a bench test to check where it was leaking. #3. Focused on it, and it's the fuel "t". Fixed it with JB weld. I'll probs replace them with the brass one's. But, for now it's fixed. I'll tune it this week, and begin riding it.
    • 8672
    Yep, if the bike isn't used regularly, the rubber on the fuel T's shrink and cause a leak. They may or may not swell back up and stop leaking after some use. Not to mention they are 40yrs old. Anyway, replacing them with the brass O-ring type is a good call.
      • 3917
      Hey Phil- it actually split!
        • 7640
        You can cut all the "rubber" of the sides of the "T" and put "O" rings on it. I did that a few years back on one of my bikes, before the brass fittings were available. I used nitrile(sp) o-rings from HF, and they were still working when I sold the bike after two years of riding.
          • 8672
          Yep, the brass T's are readily available now on Ebay for about $11 each. I have used them for several carb bank rebuilds and they are of good quality.
