Throttle Cable Assembly Recommendations
  • deanstrickland
    • Feb 2021
    • 16
    • Edmonton, Alberta
    Hey guys, the PO put a throttle assembly on this bike that simply does not work with our throttle cables. The L shaped metal end was just stuck into an open (not threaded hole) and is not secured into the assembly. Whenever I am backing up with the bike running the cable can get stuck and rev the engine.
    The other hole in this assembly looks too large and I don't have the threaded fastener for this assembly. To be honest Im not even sure what to call the threaded adjuster/fastener/thingy.
    Looking for any recommendations for a complete assembly, with tube (7/8) that will work with the motion pro cable 05-0069.
    Edmonton, AB
    1980 xs1100S
    • 2104
    That looks like a push-pull throttle like on a Honda , where another cable comes out of the lower hole and goes to the carb also.
    Not correct for the XS11.
    Andreas Weiss probably has an assembly for ya.
      XS650.com also has the correct throttle assembly, if you want a new one. Any mid '70's to early 80's Yamaha should work. You could probably use a dirt bike assembly as well, if it's a single cable type.
      • deanstrickland
        • Feb 2021
        • 16
        • Edmonton, Alberta
        There is a local motorcycle salvage shop 2km from my place with a ton of old Japanese bikes, ill bring my cable there and check it out then
        Edmonton, AB
        1980 xs1100S
          If you have that luxury then just find a replacement off of an xs100 if they have one. There are also some aftermarket replacements on Ebay. They are brand new ... just not original but made to look and work just like the Oem.
          • deanstrickland
            • Feb 2021
            • 16
            • Edmonton, Alberta
            cajun31 Im looking at getting Motion Pro to make me a cable so I can use a stand alone throttle assembly. Im removing the oem ign/kill switch/throttle assembly from my bars. Of course its busy season, I can barely get any replies from them.
            Edmonton, AB
            1980 xs1100S
