Xj1100 project
  • Mpl
    • Jan 2021
    • 4
    • Southern Ontario
    Xj1100 project
    Good afternoon,
    I purchased a 1983 XJ1100 a few years ago. It has been a great bike. This winter I decided to tear it down. I am working on the lower half of the crank case and noticed a hole. I’m not sure if it is supposed to be there. Does anyone know if this normal?
    thanks in advance
  • Mpl
    • Jan 2021
    • 4
    • Southern Ontario
    Here’s a better picture the hole is at the bottom.
    • Bax
      • 344
      • Merrimack, NH
      Hi Mpl, Welcome! Not too familiar with the XJ case casting but I'm sure some on here are. Is that bore where an alignment pin sits? Pit goes thru to the webbing support?
      ---Bax
        • 8930
        The XJ11 cases are the same as the XS11, you can even see the 2H7 stamped into one, about the hole, IDK.
          • 7831
          It's been running well before teardown, don't worry about it! I'll look at my '78 bottom case later this week and see if it has the same thing.(If I can get to it!)
          To me it looks like something Yamaha has done at the factory.
            • 8930
            If this is what we are looking at, I have a case nearby I can look at...
              • 8930
              Looks like my 79 case is drilled all the way thru. The other side of the case that mates up to that hole goes to a dead end chamber so I would think it shouldn't cause any problem. If any oil is going thru there it would be the middle drive oil.
