vacuum orifice ?
  • Adolph
    • Nov 2020
    • 54
    • San Antonio
    vacuum orifice ?
    is there supposed to be an orifice in vac advance line ??????
    Adolph Spitta
    MM2(SS)
    Someone may have put some type of restrictor in the line to minimize vacuum advance plate chatter. Nothing wrong with doing this. An old pilot jet works well for this.
      Hey Adolph,
      Make sure your vacuum advance line is connected to the #2 carb body port tube, NOT The Intake BOOT Synch Port. IF so, that may also be why the PO put in a restrictor. The Port on the #2 carb body IS metered, and shouldn't need a restrictor valve device.
        Yeah, if the carbs are not synched properly, the restrictor helps. +1 TC on having the hose going to the +2 carb body. I'm sure Adolph has it hooked up correctly.
          Write something...
          • Bax
            • 344
            • Merrimack, NH
            Hi Adolph, Wondering why you are asking. Did you find a restrictor in the line that seemed out of place or did you notice the vac advance pulsing?
            ---Bax
            • Adolph
              • Nov 2020
              • 54
              • San Antonio
              thanks for all the input, anxiety level lowered, buyer should be here saturday from new york. hoses are hooked up correctly
              Adolph Spitta
              MM2(SS)
