Where to tap or pry head for removal?
  • 2WheelFun
    • Aug 2020
    • 266
    • Pittsburgh PA
    I have the 8 acorn nuts and the 2 12mm center nuts off and don't want to break anything. I've been pounding on the 1 & 4 manifolds at the bottom and no joy. I've been lightly prying under the exhaust studs of 1 & 4.
    Where's the sweet spot to break the head gasket seal? Please help before I go ape .... on it.
    1979 XS1100 Special
    1980 XS1100 Std parts bucket
    1987 ZL1000 Eliminator
  • 2WheelFun
    • Aug 2020
    • 266
    • Pittsburgh PA
    Well now if I'd look at a book or clean the debris off my parts bike head I'd see all the bolts.... eye's ain't what they used to be
    No big bore kit in there, oh well, maybe I'll have some better luck with the lottery this evening.
    1979 XS1100 Special
      • 8930
      Don't forget the two hex nuts in the center front and rear.
      Now there are specific pry points if you plan on removing the jugs.
      • 2WheelFun
        • Aug 2020
        • 266
        • Pittsburgh PA
        Thanks Phil. It lifted right off once the innermost acorn nuts were excavated from the dirt and debris. It should have been obvious that there was 4 studs around each hole.
        1979 XS1100 Special
          • 7830
          build a few wooden wedges for removing the jugs! four of them will help. Also, CLEAN all the studs best you can before trying to remove them. The dirt on the studs will keep the jugs from moving very far, DANHIK.
            • 3352
            Good idea on the wedges, will use that next time I pull the head on a cycle.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
