sure sounds noisy
  • Adolph
    • Nov 2020
    • 54
    • San Antonio
    sure sounds noisy
    just about finished with project, carbs ,intake boots,,,,,,,,,,,,etc
    buke sat 5 yrs, new paint and runs and idles great but timing chain noise seems loud 32000 miles
    Adolph Spitta
    MM2(SS)
    • 2075
    Have you checked the adjustment of the cam chain ?
    Here's a link with tips:
      • 256
      Howdy Adolph,,,,,also change the oil if its sat for so long, good chance there is gas in it and it thins down the oil A LOT. Like Schming said adjust the cam chain,,,front of engine, 5 minute procedure,,,,,,get back on results,,,,Mike in Sun Diego
      • LenB
        • Nov 2020
        • 148
        • Winnipeg, Manitoba, Canada
        Installed a manual cam chain adjuster and never looked back. Sounded like somebody dumped a bag of marbles into the crankcase. Original cam chain adjuster can back off when downshifting and create dangerous looseness. Something to consider. Also may contribute to noises - carb synchronization?
        1980 XS1100G (one owner-me)
        1984 Honda VF750S V45
        Owned - 1976 XS750D
        Owned - 1972 Honda CB750
        Owned - (unknown year) XS650
          • 3231
          The original CCT is a manual adjust... Did you mean ACCT is what you installed?
          ZRX1200
          • jkorn
            • May 2003
            • 187
            • Wickenburg AZ
            Good to verify adjustment. But it never was the quietest on mine. I have not replaced the original. Jk
            Jeff Korn
            Original Owner 79XS1100 E
              • 8753
              Manual tensioner... Click image for larger version
                • 1881
                I would definitely check for excessive wear on the chain first. If still within specs ... get and ACCT and install. Won't have to worry about manual adjustments.
                • LenB
                  • Nov 2020
                  • 148
                  Bonz - full manual adjuster - like bikerphil posted. Installation of that and replacing the cam chain made for a nice quiet, happy motor. Important to adjust it properly - overtight can be an issue, too.
                  Owned - 1976 XS750D
                  • Adolph
                    • Nov 2020
                    • 54
                    • San Antonio
                    have serviced engine , changed oil , carbs ultrasonic cleaned, all fluids,did chain adjst accord to factory service manual, sounded great for two starts on lift third time chain loose again , readjusted and now sounds finer,,,purchased raptor 660 acct on ebay 20.00 any mods to raptor needed?????
                    Adolph Spitta
                    MM2(SS)
                      • 7712
                      You may need the shorter bolts from the raptor, but I'm not sure. Look at the boss for the bolts on both, and if the ACCT boss isn't as tall as the old one, buy 5mm shorter allens for it. I usually replace everything with SS from Ace Hardware.
                      • Adolph
                        • Nov 2020
                        • 54
                        • San Antonio
                        will check as soon as i get it , thanks so much
                        Adolph Spitta
                        MM2(SS)
                          • 3231
                          Gotcha. The confusion came because guys that have been around here a long time typically swap in an automatic cam chain tensioner from a vision or virago or something similar. So when you say you installed a manual cam chain tensioner that typically is counter to what guys have done over the years.
                          When I did my ACCT mods to a couple XS's (can't recall if Vision, Virago or Raptor ACCT) I had to elongate one of the holes just a tad on one of the ACCT's and I believe I used different bolts that came with the other ACCT as per what DiverRay said.
                          ZRX1200
                          • Adolph
                            • Nov 2020
                            • 54
                            • San Antonio
                            just got raptor acct in. seems just a little long, won't engage first notch
                            Adolph Spitta
                            MM2(SS)
                              • 1881
                              I can't really say anything about a raptor acct. I have always used the old Vmax tensioners. They bolt right on without any modification necessary. Maybe someone else can comment on the raptor type.
