How I remove those pesky pilot screw plugs
    • 1897
    Would love to be able to attend one of those. I was stationed in Idaho back in the 70s and drove through Colorado several times... north to south. Beautiful country.
      • 7738
      Bonz, I'll have to try and make the 2021, IF SWMBO doesn't have other plans...
        • 3231
        Hope it works! Tried to send you a PM but your box is full.
        ZRX1200
          • 7738
          Bonz, Cleaned some of the OLD stuff from the box, 2011 and older!
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            You can also use a small slide-hammer to pull the plugs but I rarely found it necessary. I have one in my tools but rarely used it for this purpose and then only when I felt the plug was otherwise too hard to get into.
            Putting a sleeve on the drill bit so you can't go into far is well worth the time and effort to make one up... Actually after making one, I found I could use a drilling guide from my Snap On broken stud extractor set but not many have those and I'm not sure if I still do either...
            Tony
