manual petcocks
  • Adolph
    • Nov 2020
    • 54
    • San Antonio
    manual petcocks
    who knows what manual petcocks should use 1978 1100e
    Adolph Spitta
    MM2(SS)
  • Bax
    • 344
    • Merrimack, NH
    Hi Adolph, you looking to replace or rebuild the petcocks?
    ---Bax
    • Adolph
      • Nov 2020
      • 54
      • San Antonio
      replace with manual
      Adolph Spitta
      MM2(SS)
      • Bax
        • 344
        • Merrimack, NH
        Don't have too much to go on but you may find something that that you're looking for here.
        ---Bax
          • 7818
          If you take the petcock apart, you will see a lug on the selector. Cut the lug and you can spin it to an "off" position. Been there, done that!
          Just use prime for run, but watch your miles as you will not have a reserve.
            • 8893
            Pingel makes some but be prepared to spend some money. You'll need the correct adapter plate for an XS Standard..
            • Adolph
              • Nov 2020
              • 54
              • San Antonio
              thanks so much, will get fuel gage up to speed
              Adolph Spitta
              MM2(SS)
                • 8061
                MikeXS has new ones if that's what you want. The one in the link will fit the XS1100 standard. Be advised there is no left and right, so if you use them on both sides of your tank, the handles will operate in opposite directions.
                  • 2138
                  I installed those petcocks on two of my bikes and I like them a lot.
                  • e30 gangsta
                    • Mar 2016
                    • 142
                    • Lone tree, Colorado
                    I have the same petcocks and the leak sometimes they suck lol. You also have to chop the res tube because its too tall and you run out of fuel when theres still over a gallon left in the tank lol
                    80 XS1110 SG, RD400
                      • 1987
                      I was curious about those raised internal tubes. I was using a stock special petcock as a reference where you basically have no tubes at all .... just the net filter in a cavity. Thanks for sharing.
                      • Adolph
                        • Nov 2020
                        • 54
                        • San Antonio
                        thanks to diverRay, ground off tab, awesome idea, now i can keep reserve option and have a manual off, the leakby when shut down, the leak by was miniscule, so can still run on main and reserve, but have a manual off thanks again
                        Adolph Spitta
                        MM2(SS)
                        • 2WheelFun
                          • Aug 2020
                          • 266
                          • Pittsburgh PA
                          The stock petcock filter is two sided, one side for on that has solid sides to the small portion of screen on top, the other side for reserve/pri has screen to the bottom. The "tube" is built into the OEM plastic filter.
                          1979 XS1100 Special
                          1980 XS1100 Std parts bucket
                          1987 ZL1000 Eliminator
                            • 1987
                            I just got done examining an old net filter ... or actually several and see what you are saying. the tube is built in internally and to about that height. Same for both the standard and special net filter. I just happened to have both... although I don't own a standard. So ... that begs the question concerning this replacement petcock. Was it or rather is it geared for bikes with or without an octy or either or? Second question would be I am presuming that the right side of the petcock tubes with the lower pipe .... which is flush with the petcock in the net filter feeds the reserve?
