Pickup coils ate themselves today.
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Not sure why, or how bad, but I won't give up.
    it happened at about 65mph. Just started sputtering and backfiring and then died. I look down and see this.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
  • GLoweVA
    • Jun 2011
    • 1957
    Got home and took the cover off. OMG.
    looks like the vacuum advance came loosec and it over rotated.
    The Green Monster
    Got him in '04.
    Scarlet
    Got her in '11
    Hugo
    Cold weather ride
    • GLoweVA
      • Jun 2011
      • 1957
      Got some debris in the cover too.
      The Green Monster
      Got him in '04.
      Scarlet
      Got her in '11
      Hugo
      Cold weather ride
      • Bax
        • 344
        • Merrimack, NH
        Hi George, I thought I was having a bad day.......... Have you ever had or know of that bolt being removed from the crank end before?
        ---Bax
        • GLoweVA
          • Jun 2011
          • 1957
          ---Bax
          Yeah I've had that bolt out a few times. Last time I think I put loctite on it. Must not have torqued it enough.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
            • 2066
            That's a failure mode I don't think any of us has seen before.
            Easy to diagnose.
            Hope it's easy to fix.
              • 8796
              Maybe a drop or two of thread lock blue this time? That's brutal.
              • dpotter58
                • Aug 2004
                • 1847
                • Southern Maryland
                Good to see you back on here
                1980 LG
                1981 LH
                • red bandit
                  • 955
                  • central michigan
                  That pic is awesome. Sorry for you troubles.
                  79 SF parts bike.
                  • shutchis
                    • Oct 2004
                    • 191
                    • Deer Park, TX
                    Wow, that's a sad looking disaster. Do you need some parts? I think I have them in my parts bin. I replaced two bikes, my XJ and XS 11 ignition systems with a GM DIS unit when I fuel injected these motorcycles. Let me know and we'll work the details.
                    '80 XS1100LG Midnight Special
                    Looks like an '82 Maxim, Fuel Injected
                    '82 XJ1100J, Fuel Injected
                    Stan Hutchison
                      • 3237
                      So sorry on that issue! Definitely not something that loses clearance in there on its own, I wouldn’t even hesitate to use red Loctite as it still can be removed when needed. However, thinking Loctite was used versus putting Loctite on it could explain a lot. Do you see any on the threads? Usually fairly easy to see even a small speck of it as residual.
                      ZRX1200
                      Seca 750
