bike doesn't perform like it should
    80-81 YAMAHA XS1100 CARBURETOR SLIDE PISTON & RUBBER DIAPHRAGM
    At $20 each, these are going to be tough to beat. They came up on another forum. No complaint listed. The diaphragm is as original.
    Hey Marty,
    Just out of curiosity, I vaguely remembered they were the company based out of Japan that offered the inexpensive big bore piston/rings sets for our bikes, so I looked through their selection. Much to my surprise, they have added th 0.5 and 1.0 mm regular oversized piston/ring sets for the 78-79 engines. This is for folks with just enough cylinder wear/warpage/rust that requires some boring, but not the extreme big bore size...which can let someone have the chance to perform another bore/piston upgrade to their engine later if so desired. However, the bottom end parts, crank bearings are extremely rare now, so if someone has enough wear to require a bore, might as well go BIG or not at all?? Just wanted to mention this. We need to add this link to our links page with descriptions of these critical parts availability.
    Just a reminder, these are CAST pistons, not Forged, but STOCK is also CAST, not forged, hence the cheaper prices of $130 for the little bores, $170 for the big bore kits, much cheaper than the $500++ price tags of the WiseCo Forged pistons! YMMV!
      • 8077
      Hey Marty,
      That's right TC. Several of the XS11 faithful have installed Cruzin' Image pistons.
        • 3352
        Have you checked to be sure the diaphragms are secure in groove? Many times they will be that way and by the time the carb top goes on they are not that way. Unless you have verified there are holes in the diaphragm these things last a long time.
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • Gord
          • 7
          • Parksville British Columbia Canada
          Thanks Bonz pulled carbs out and the diaphragms on three of the carbs were not in right. My bike is a 79 but the carbs i just found out are the 1980 to 84 model . When i had some wiring issues with bike wiring diagrams matched the 80 bike, I think it was a late run 79 and some of the 80 parts were being put on
            • 5073
            I had 4 to 1 Jardines, and K&N pods, running at 8500 feet elevation. Tried Mic 142.5 mains.
            Pulls hard all through the range.
            Did not test maximum speed.
            End result: 45 pilots, 142.5 mains, 1.25 turns for pilot screws, 1.007
            inch float height avg. I was getting 33 mpg and quite happy with that.
