1981 Eleven Special Rear Wheel size.
  • Banshee's Veil
    • 104
    Hello,
    I just bought a 1981 Eleven special, I'm in the process of getting her running. I took off the rear wheel and it's a 17"? I thought the specials had 16" rims? anyways, it does have the supporting plate for the rear caliper and another spacer between the caliper itself and the bearing. Does this mean the PO did a 17" wheel mod and all I have to do is swap it back to 16"?
    • 8077
    Originally posted by Banshee's Veil
    Hello,
    Yes, you'll need the 16" wheel and the stock spacers. No Special came with a 17" wheel.
      • 8930
      The 17" wheel was most likely put on to lower the cruising RPM of the engine. When you go back to 16", be aware the engine RPM will be a bit higher and the bike will have more off the line power.
      • Banshee's Veil
        • 104
        Havent even rode it yet so I wont notice lol
        • Banshee's Veil
          • 104
          So after lots of failed research, Dennis Kirk's website states that the 1981 XS1100SH has a 17" rear?
          also how many parts/what parts do I need to put a 16" on?
          • 2WheelFun
            • Aug 2020
            • 266
            • Pittsburgh PA
            Why not just buy a new 17" tire and run what ya brung? They are the same style spokes, looks like it is original to the bike if it is off a std and probably provides a couple more tire options.
            1979 XS1100 Special
            1980 XS1100 Std parts bucket
            1987 ZL1000 Eliminator
            • Banshee's Veil
              • 104
              I want the 777 Whitewalls
                • 8930
                https://www.partzilla.com/catalog/ya...0sh/rear-wheel
                #33 is the spacer that is different between the 2 wheels. Who knows maybe the PO didn't change the spacer to the 17" wheel type. If you could post a picture of the right side of the axle, someone will tell you which one you have.
                • Banshee's Veil
                  • 104
                  Thank you I'll post a picture this afternoon
                  • Banshee's Veil
                    • 104
                    Here is everything that was on the axle before it was removed. 1 spacer/cover net to the wheel bearing, one caliper bracket, and a spacer that would be inserted into the caliper itself. Is this a 17" or 16" wheel set up?
                      • 8077
                      I believe an adjustment (spacer change) was made to accommodate the 17" wheel. You'll need the correct spacer.
                      Well, Dennis Kirk is wrong. SF, SG, and SH only came with a 16" wheel.
                      The OE tire size for the standard XS1100 is no longer produced. 130/90-17 is wider that the OE tire. The 16" wheel is wider than the 17" wheel to accommodate the 130/90-16 tire.
                        • 8930
                        Yep, the spacers in your pics are for the 17" wheel, the 16" wheel only uses one spacer, similar to the one in your first pic but wider (#33 in the fiche). The bracket shown in the 2nd pic is correct for the Special 16" wheel, no need to replace that.
                        • Banshee's Veil
                          • 104
                          Thank you, yes they are wrong. The PO has a parts bik they are letting me grab the 16" wheel from. It's not the same year however, it has a spiral patterns opposed to straight spokes. Does that matter?
                            • 2160
                            ... it has a spiral patterns opposed to straight spokes. Does that matter?
                            No problem functionally. Must be from an XJ.
                            If it were me, I would want the front and rear wheels to look the same.
                            • Banshee's Veil
                              • 104
                              So no spacer between the caliper and bracket? Just between the caliper and bearing?
