Hi there.
So I have an standard XS 1100 '80 that I bought recently and am going through piece by piece. I removed the carbs cleaned them up thoroughly and put on new carb intake manifolds. I did a bench tune and a sync with the carb synchronizer on the bike. All seemed to be tickety-boo until the bike warmed up on her first ride. The revs stay at around 2.000 rpm when standing idle for a good while before occasionally dropping to normal levels. Occasionally as in, once in a while after standing with a high idle they will drop to normal levels. Went back to the drawing board and have found that the problem comes from the hose attachment from the left petcock to the number 2 intake manifold. If i detach it from the petcock it idles fine. If I block the hose with my finger the problem arises.So this would indicate some sort of blockage in the petcock.The bike was idling fine before the carb service and I haven't touched the petcocks.
I guess my question is, how exactly do the petcocks on these things work, should I clean the petcocks
even though they were functioning before or what am I not seeing here. Any experience here would be appreciated.
