Been a while, but I'm back at work on this. I was NOT able to get it running well last fall. I think I know what part of the problem is, but more on that later. The bike is getting a "refresh" on the paint, as one side cover was red, the correct one was black. I found a local shop that mixed the paint I wanted, and put it into spray cans! $25 each, but a lot easier than cleaning guns for a small job. I'm going to paint my large tank at the same time, so for long travel I'll go to a 6 gallon tank. The stock tank had some rust on the underside, so I've used an encapsulation paint to take care of it.
The seat needed a support for the '79, as well as a cowling for the rear. Picks of that as well. I hope to have it off to get re-covered next month, as I'm out of funds for this month. The down side of retirement and a fixed income...
Awake after a few years sleeping
Yes, the bike has the chrome plating on the valve cover and side cover, as well as the black paint on the engine. This bike was MUCH easier than a few I've worked on, but it still has it's little things that need work. I hope to run it at Firebird this month, to see how it does now in the 1/4 mile with a fat 250lb geezer behind the handlebars.Once I find some newer pics, I'll post them. and no, I didn't list all the things that needed a bit of work, like the welding on the bag mounts, etc.Leave a comment:
Congratulations on your progress. I know full well the work involved in nudging one awake. At least yours was prepped for it's slumber.Leave a comment:
Here are a few pics of the bike. Notice the emblem on the gas cap!3 PhotosLeave a comment:
Well, I can finally read and post on XS11 once again! Took eight months for Sparklight to flush their server DNS....
OK, to start the story MRO called me last summer and said he wanted a new home for his SF. It had not been running for about four years, but he put it to sleep properly. I picked up the bike, and two weeks later it was in a POD, ready for a move to Idaho.
I spent this past winter going through the bike, checking valve lash, carb float levels, brake masters and calipers, and new tires and battery.
I was able to have a local company build new brake lines, and did need to replace the front MC as it was badly pitted inside.
The bike had a seat from a SG, so it needed to be modified to work, as it was all I had. It still needs a new cover, but it works and I can remove the side covers.
New Michelin tires, LED lights all around, and it's running. I have a Vetter fairing, trunk, and bags as well, so it's "sort" of a touring bike. I'm still working on the carbs, but it is getting closer to road trip worthy.
I'll post some pics in a bit, once I've figured out the new system we have.
Leave a comment:
