.. what position are your needle jets in? the clip should be in the middle grove and what color are your plugs? clean or put in a new set of plugs and go for a ride, try to keep your rpms at around where your problem exists for about a mile then pull the plugs to see if they're to dark or to light.. more than likely they will be too dark.. also try to pay attention to where in the rpms your problem starts and where it ends and if your problem happens every time and at the same time, and does it run like crap after idle and pop then suddenly come on like a freight train and does it idle nice on all four cylinders?..
.. this will be helpful in determining if your problem is with the carbs/jetting or the ignition
