stupid tire question....
  • dorkpunch
    • 32
    stock tire for my 78 xs 11 is a 4.50h17, which converts to a 120/90-17. Is that correct?
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    I'm pretty sure that the size is a 130/90 17" At least that all I've ever seen on the back of XS11 standard models.
    Geezer
      • 7737
      I run a 130/90 17 on my '79 standard. I will be getting a new tire soon, and my try for a 140/90 17 if I can find one. I know if you get a blackwall, no raised letters, it just fits.
      Ray
      • Doo-Daa
        • 53
        • Amarillo, TX
        My '78E has a 130/90 - 17 rear, 100/90 - 19 front.
        Both are raise white letter tires.
        FWIW
        Doo-Daa
        • MartyA
          • 2148
          • NW PA
          The standard came with 120/90 but a 130/90 will fit. I ran 120/90 forever, just in the past year put a 130 on. No real diff noted.
          Not sure q 140/90 will fit on a standard, not much room 'tween the tire and the drive shaft. A 140/90 does fit on a Special.
          Marty in NW PA
          This IS my happy face.
          • Do Lee
            • Feb 2003
            • 255
            • Victoria, Texas
            I have a 140/90 x 16 RWL on my 79 SF tire rubbed on the rear drive arm. I had to shim the wheel/tire away from the drive shaft until it stopped rubbing by adding a washer between the clutch hub and final drive ring gear.
            Do'Lee
            XS1100SF "Green Hornet"
            (1) XS1100LG "Midnight Dream" Restoration has begun.
            (2) XS1100LG "Midnight Madness" Waiting to be next
            (5) multi partsters for bobber "Ruby Red II" On the list.
            SR500H "Silver Streak"
