Air Intake - Pros and Cons...
  • Street_Rat78
    • Sep 2005
    • 253
    • Columbia, SC
    I've spent the last two days reading through threads on Intake Boots and Air Filters and I just can't seem to find an answer to my question.
    Are there any obvious pros and cons with going with one or the other?
    My bike's PO pulled off the air intake long before selling it to me. He gave me the part when I bought the bike but told me I probably wouldn't need it. I'm just curious as to how everyone else has theirs set up.
    15
    Air Intake Boots
    26.67%
    4
    Air Filters
    73.33%
    11
    Other...
    0.00%
    0
    ~ Street Rat ~
    Mitch
    '78 XS1100 "My Mistress"
    Knowledge is Experience. Everything else is just Information
  • RiskyBusiness
    • Mar 2003
    • 174
    • Richmond, Virginia, USA
    I pulled my breather box out and put in air pods. For me there was only one reason to do it: never have to wrestle with the air box again. After taking the box out to clean the carbs the first time I knew that I didn't want to have to do that again. I also had a feeling I would be back in the carbs again frequently. This turned out to be totally correct as I have been in the carbs a number of times. The pods just make my life easier.
    RB
    1979 XS1100 Special with 81 carbs
    • cueball
      • Jun 2003
      • 375
      • Nth Albury NSW Australia 2640
      Pod filters are the way to go. Easy to wash out, dry, spray with filter oil and put back on. Bike looks better, unless you want to go the restoration route.
      • wildbill
        • Feb 2003
        • 346
        • western NC
        I removed the airbox also and for the same reasons. I then used the stacks out of the old airbox and fitted foam filters on the ends. Looks good and can reach the idleset knob with no problems.
        Bill Harvell
        • Street_Rat78
          • Sep 2005
          • 253
          • Columbia, SC
          Pod Filters
          So where did you get the Pod Filters? Are those the metal ones?
          ~ Street Rat ~
          Mitch
          • xj11john
            • Jun 2005
            • 440
            • Lafayette, TN
            Check out this super-thread
            it has alot.....of information
            In it Bill tells of Cycle-Re-Cycle II - looks like a good place to try.cycle-re-cycle II
            '82 Xj1100j
            "Ride for the Son"
            John
            • wildbill
              • Feb 2003
              • 346
              • western NC
              I made some caps that would fit the ends of the stacks snug and then cut the centers out smaller then fitted foam filters inside the caps. Right now I`am using the outside of the stack to hold the cap and filter in place. I have not road tested yet so I don`t know if I will have to make any adjustments to this yet. Right now if everything works out it should do the trick.
              Bill Harvell
              • ernie elmore
                • 40
                • Irvine, California
                Replace Carb Airbox w/ Pods
                If you have a 78-79 XS1100 with the carb vents going to the air box, you need to do more research on the website before replacing the air box that has carb float bowl vents.
                Ernie Elmore
                1815 N Tympani Cir
                Anaheim, CA 92807
                Ph: 714-340-3173
                email: xs11ernie-mc@yahoo.com
                Still Riding at 79 for ....
                1980 Yamaha XS1100G Std - Everlasting - sold (sob)
                1983 Yamaha XV920 Virago - Enduring - sold
                1993 Honda XR650L - Enduro - gave to Son
                • strom
                  • 1577
                  • Slovenia, EU
                  I have stock airbox with... rather... skeletal... air "filter". Large debrees and mice cant get to the carbs, I don't worry bout other stuff since im not near sahara.
                  LP
                  • Street_Rat78
                    • Sep 2005
                    • 253
                    • Columbia, SC
                    So have most people gone the route of Air Pods? I was looking at mine last night, and think I'm going to pull off the filters I have on there now and put a set of Pods on.
                    Thanks everyone for your input.
                    ~ Street Rat ~
                    Mitch
                    • Pat Kelly
                      • 3046
                      • Golden Valley, AZ
                      Both my XS's and SWMOB's XV have stock airbox with OEM style K&N filter element. One of my XS750's has pods (never ran since I got it) and the other has no carbs or airbox.
                      Pat Kelly
                      <p-lkelly@sbcglobal.net>
                      1978 XS1100E (The Force)
                      1980 XS1100LG (The Dark Side)
                      1999 Suburban (The Ship)
                      1994 Dodge Spirit (Son #1)
                      1968 F100 (Valentine)
                      • xj11john
                        • Jun 2005
                        • 440
                        • Lafayette, TN
                        Steetrat,
                        My xj1100 has had pods and 4-1 exhaust, since I got it, it appears that the carbs have not been rejetted, but seems to run fine. Alittle lean on one cylinder, but seems to be straightening out since I have been into the carbs.
                        Ive heard stories here about the nightmare an airbox on an xj can be, and am glad (esp. with the amount of times Ive had the carbs off) that mine has pod filters.
                        '82 Xj1100j
                        "Ride for the Son"
                        John
                        • cueball
                          • Jun 2003
                          • 375
                          Partsnmore.com or bikebandit.com for the pods. Went from 110's to 112.5's, 42.5's for pilots with free flowing 4/1, runs fine.
                          • stevo
                            • Oct 2005
                            • 64
                            • buford georgia
                            in my opinion bike looks better with stock airbox..it's certainly quieter...won't let in rain....i've had my airbox off several times (playing with jetting) it gets easier each time. the only reasons i see to run pods are ( 1) going racing (2)don't have original ( 3) lazy (4) no mechanical ability... my bike idles smooth and runs like a bat outa hell./. ithink i like this thing
                            • cueball
                              • Jun 2003
                              • 375
                              5/ less **** to carry around, 6/ less reason to put off servicing the carbs, 7/ pods & rejetting makes them go better again.
