so for the tech guys out there has anyone seen anyone switch from carbs to throttlebody fuel injection ??
I plan to do just that..
I am a designer and machinist i will be putting this unit on a flow bench and figuring out the throttle diameters.
i may do just one 105mm port or do a dual unit. on slightly smaller than the other..
i will be machining the entire manifold from aluminum. no casting ..
i will also be opening up the ports from a 38mm to ???
any input on this would be greatly appreciated.
