intake manifold, fuel injection
  • ROCCET933
    • Sep 2005
    • 8
    • orchards washington
    so for the tech guys out there has anyone seen anyone switch from carbs to throttlebody fuel injection ??
    I plan to do just that..
    I am a designer and machinist i will be putting this unit on a flow bench and figuring out the throttle diameters.
    i may do just one 105mm port or do a dual unit. on slightly smaller than the other..
    i will be machining the entire manifold from aluminum. no casting ..
    i will also be opening up the ports from a 38mm to ???
    any input on this would be greatly appreciated.
    Hey there Roccet933,
    Check out this thread:
    Fuel Injection Thread
    • 81xsproject
      • 3185
      • Fortuna, CA
      for the few of us on a similar quest, KEEP US POSTED, PLEASE...
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • ROCCET933
        • Sep 2005
        • 8
        I am currently designing a 3d surface area of the intake system. including aluminum standoffs from the intake on the motor..
        it will eliminate the rubber gaskets.
        the fuel injections is still being discussed..
        i will post the drawing when proto type is completed.. this may take several weeks to a month to complete depending on how busy our mold shop is.
