Oil sight glass issues.
  • seriousjimmy
    • 21
    • Los Angeles
    Hello all!
    The '80 Special is running like a champ...
    Have a question about cleaning the oil sight glass.
    Saw elsewhere on the site that 'cleaning tech tips' exist, but haven't seen any definitive answers other than to take apart the cases...would rather not do that.
    Any ideas?
    Best,
    SJ
  • rwtrail
    • Sep 2002
    • 33
    • Estill Springs Tenn.
    Oil Site Glass
    Hey SJ, I guess to clean the inside you must open the case.
    Hold er Nute she smells alfalfa
    • mitch
      • Oct 2002
      • 934
      • fredericton new brunswick canada
      clean
      When you change your oil, put the plug back in and add 2 liters of raw gas shake the bike around . drain the gas out let it sit a while top up the oil. Should be cleaner other than that take the case off. .........MITCH
      Doug Mitchell
      82 XJ1100 sold
      2007 Stratoliner 1900 sold
        Well, the glass is held in place with a metal slotted piece, to allow the oil to flow around it. After draining the oil, you could try some spray carb cleaner on a straw, and you may be able to aim it around the corner of the filler spout. Also, you can try affixing a long cotton swap/Q-tip onto the end of a stick, dip the tip in carb cleaner or solvent, and then swab the glass as best as you can poking it inbetween the metal slots that cover the glass from the inside. Also, try adding some Mystery Marvel oil in it BEFORE draining it, run it for a few minutes at normal temps, just don't rev the engine hard OR drive it, no real load on the engine. It removes varnish and gums from the engine and doesn't harm the plates! Then drain and refill.
        However, if you need to pull the cover for clutch replacement, then it's easy to access and clean!
          dipstick
          You can see through mine OK but because my sidecar gets in the way the only way to see the window itself is to carry a little mirror on a telescoping tubular handle. Lucky me that I got such a thing as a birthday gift a while back, right?
          What I want to know is what dipstick decided the XS11 didn't need a dipstick?
          Fred Hill, S'toon.
          • seriousjimmy
            • 21
            • Los Angeles
            Hey Gents!
            Thanks for the timely tips. Will be able to get to this issue a little later today.
            Best to all!
            SJ.
              Let us know what works best!!
              • xs650mike
                • 1286
                • Lake County, California
                ...sidecar gets in the way...
                Fred, how do you get an accurate oil level reading since when set up properly the bike usually leans away from the sidecar slightly? Do you sort of guestimate?
                Shiny side up,
                650 Mike
                XS1100SF "Rusty", runs great, 96k miles
                XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
                Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
