Replacement Fuse Block
  • jacksf
    • 193
    • Daly City, CA
    I did a search..soooooo many results its quicker if I just ask here.
    Is the JCW replacement fuse block still the recommended one for my XS1100F?
    Thanks
    Jack
    82 XJ100J Gone
    83 XJ750 Seca
    Hey Jack,
    I can't recall which one the JCW one is right at the moment? I can't find one like the one I put on mine a couple of years ago!? I got it at PepBoys. But now, the only one I can find has a much taller mount base......I reckon it could be trimmed down, but not sure how to mount it, since you'd have to cut the mounting brackets off to get it to sit lower!? Whatever you get, just don't go back with glass fuses, get the solid plastic spade styled ones instead!
    Found the link and photo: Yes, that's like mine but it has an extra slot, mine only had 5! Do a search for FUSE BLOCK and you'll find a thread that mentions other locations and types!
    • randy
      • Dec 2003
      • 4521
      Jack,
      Ditto what T.C.wrote. The box I used is a 5-slot Littlefuse #350417BP available at Pep Boys. Here's a link to how I installed it:
      XS Resto Tips
      • Winterhawk
        • Jun 2004
        • 684
        • Missouri
        If you want to keep an OEM setup I have been using Radio Shacks Grey fuse blocks. Remove the old fuse block and grind down the inside of the black case. Then pop rivet the new in place and solder the wires to it. Paste the sticker in place.
        • dewibp
          • Jun 2005
          • 315
          • Work out of Dakota Dunes SD but live in eastern Iowa (Quad Cities)
          I used a partsnmore fuse block assembly that matches up exactly with what is there if you want to go back to as original as you can. If I rember correctly, do a search for partsnmore.com, search for yamaha, then xs1100, scroll down and for $30.00 you have an exact replacement. It requires you to cut into the wire loom. Included all parts and end connectors as well. Easy installation.
          DEW
          One Red "Creation 1"
          One Black"Creation 2"
          One Black"Creation 3"
          One ???? "Creation 4"
          One ???? "Creation 5"
          One ???? "Parts Bike"
          All the above 1100 Specials
          78 Standard (Ruf Ruf)
          1980 Midnight Special
          1978 650 SE
          • jacksf
            • 193
            • Daly City, CA
            Thanks guys for your advice and assistance.
            I previously bought one for my XJ750 and my XJ1100 but don't remember where, its making me crazy.
            I am not going to do any cutting into anything Most I will do is trim it back to fresh wire so I can use the crimp on connectors.
            Geesshh now I find out that without the fairing there is no headlight, ears or anything else. So its off to ebay..again.
            Jack
            82 XJ100J Gone
            83 XJ750 Seca
              One of the Xsives on the Yahoo groups posted this link, much better price than JCW!!!!!!
              http://www.delcity.net/delcity/servl...d=10822&page=1
              Fuses & Fuse Accessories > Fuse Blocks > 6-way fuse blocks
              6-way standard
              65 amp max for all branches
              .250" male blade (side blade insertion)
              Mounting holes - center to center 3.35-in (85mm)
              Mounting hole diameter 7/32-in (5.5mm)
              6 way standard
              73820 - ATC 6-way Fuse Block, (1 MIN)
              Price: $4.05 Qty in package: 1 UOM: EA
              • jacksf
                • 193
                • Daly City, CA
                looks just like the one I bought from wirewerks for $8 or so.
                One thing though, maybe its just the way its photographed but I don't see male connectors on the other side (cuz I can't see the other side? )
                82 XJ100J Gone
                83 XJ750 Seca
                  I was just glad to see info about it, cause I've got 2 XS's I need to rewire and didn't want to have to spend $$ for it, and didn't want to get that TALL one!!
                  • John
                    • 5117
                    Jacksf
                    Are you needing some fork ears for an xj? I happen to have a set. I recently parted out two xj11's and I still have some stuff left that I would like to get out of my garage. Pm or email me if you are interested.
                    • jacksf
                      • 193
                      • Daly City, CA
                      Thanks John but I am all set. Appreciate your remembering. Unless you want to do a camchainectomy for me
                      82 XJ100J Gone
                      83 XJ750 Seca
                      • John
                        • 5117
                        Bring it on...I need some side work to tide me over until I get back to work. You gotta supply the transportation to Texas tho...
