Special gas tank hookup
  • wildbill
    • Feb 2003
    • 346
    • western NC
    Well I hooked up the tank on my standard. My problem is gas runs out of the vacum line hookup. I`am unsure as how to proceed either block them off or join them in a T with the fuel lines or something else. What is the best way to do this? Thanks
    Bill Harvell
    If you have gas running out of the vacum line, the petcocks need to be repaired or replaced. DO NOT try to run the bike that way!!
    Take a look on the left, and read some of the teck tips, or do a search on "petcocks" to see what may help.
      Hey Wildbill,
      I'm trying to figure out what you meant in the title of your post? Did you put a Special tank on your Standard? If so, then you may not realize that the Special doesn't have any vacuum lines going to the petcocks, cause they usually use the Octopus! Both petcock outlets are fuel supply lines! One is Prime and the other is the RUN/Reserve line IIRC. Remember, the function is what the petcock handle is covering/pointing to when turned! So...you can "T" the front ones together, cap them off at the petcock, depending on whether you want to be able to have PRIME function.
      HTH?
      • wildbill
        • Feb 2003
        • 346
        • western NC
        Hey Wildbill,
        HTH?
        Yes that is what I did. After I posted I did a search and I put Ts in the lines and that solved that problem. Now I have another problem witch is slow cranking when I use the starter. Have checked the starter (good) and the wires going to it. I will check some others tomorrow. The bike acts like the timing is to high but I have got it running for a short time. Then it dies and will not start back. The starter turns it over but slowly and with a lot of effort. Thanks
        Bill Harvell
        • LoserShoes
          • Apr 2005
          • 524
          • Bangor Maine
          Pull the plugs and crank it, if it spins ok, check the timing. It you get a spray of fuel, your hydro locking.
          Steve
          73 Yamaha DT3 - DirtyHairy
          CZ 400 MX'er
          68 Ducati Scrambler
          RC Planes and Helis
          • wildbill
            • Feb 2003
            • 346
            • western NC
            Steve
            Thanks, I will try that. I will post what I find out and then go from there.
            Bill Harvell
            • andreashweiss
              • 951
              In case you want to go for the stock fuel line setup with the octopus I have the octopus with all the fuel lines on it for the special. You will need to replace the rubber lines but what I have will show you what is is supposed to look like. The rubber lines are not cracked just hard no longer flexible. e-mail to andreashweiss@yahoo.com
              • wildbill
                • Feb 2003
                • 346
                • western NC
                Steve
                I tried the starter with the plugs out, works good. I then checked my timing and it was way off. I borrowed a timing light today and will see what I can do. It is very hard to get the timing right but hopefully I will get it in the ball park. Thanks
                Bill Harvell
